For Beginners - How to Get Back Existing Station Number in A Fresh Install
  1. Go to your stats page while logged-in, by clicking following link:
    https://flightaware.com/adsb/stats/user/
  2. If you have only one station in your account, go to step 3. If you have more than one ststion, select the station number you want to restore.
  3. Copy the Unique Identifier (see screenshot below)
  4. Give following command
    (Replace xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx by the Unique Identifier you have copied from your stats page)
sudo piaware-config feeder-id xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
Why does flightaware front map show less traffic than flight radar,
PiAware: Fine for 4+ yrs and now it's not
No Such ADS-B site
Not Connectiong to FlightAware
Not listening on Port 30005- Rut Roh!
Setup Assistance
Removing site?
3.7.1 update worked but over heated
Location is wrong on Skyview, but GPS is correct
ChartBundleLayers
Installing adsb-receiver project - FA not working
Would like to upgrade to newest FA & FR24 Feeder for Raspberry Pi
PiAware in Raspbian Strech with Dump-1090 How to Install?
PiAware SkyAware Map
Sharing my data
Dump 1090 Errors
HOWTO: Airspy mini and Airspy R2: Piaware / dump1090-fa configuration
Feeder blacklisted due to duplicate feeder ID?
Dead dongle?
My feed is offline, and i need assistance
No aircraft showing on SkyAware
PiAware assistance
Piware not working properly
No positions reports
Re-connecting to existing FightAware Account
Odroid N2 & Airspy - Now running!
Using the same licence key
New Raspberry Pi available - Pi 4
Unique Identifier: xxxx Assigned to PlanePlotter sites for transition?
Upgrading to a new Raspberry PI - without losing Ranking & Data
External IP address not working
Downloading and installing Dump1090-fa problems
Stopped sending data on 01/01/2020
Merge Feeder Site?
dump1090 is NOT producing data on localhost:30005
Another MLAT problem
Reactivating an old receiver station from about a year ago -- all is working now!
Results from FlightAware 1090 MHz ADS-B Antenna - 26 in
Local IP
Unable to access Dump1090 data
ADSB Receiver Project Cleanup/Convert to FA
Adding feeders
Replacing Pi- Can I add my existing Key like FR24 or do I start over?
Reinstall without getting a new site?
Announcing PiAware 3.8.1!
No Dump1090 Local
Transferring existing key to a new install
Substitute AirNav FlightStick with FA Pro Stick Plus?
Made wrong turn during V 4.0 upgrade
Application-specific initialization failed - piaware on raspberry
Unwanted site
I can't get my Piaware 3.5 or Dump1090 to update by sending a command
Announcing PiAware 5!
Wrong map
FlightAware On OctoPi
Both feeders 'dead' this morning
Problem with reinstallation after SD crash
Radar360 & Flightaware
Problem linking my account to my PiAware Server
PiAware 9 is now available
Problem after updating to piaware 5.0
Replacing old RPi with new
Replace old Feeder-id or existing feeder with new Feeder-id
I think my SD card died, how to restart again as quickly as possible?
PiAware for RPi OS Bookworm
A few questions piaware related
FlightAware with Raspberry Pi Desktop
Piaware doesn't associate with account
New SSID and Password
Install dump1090-fa at a new Raspberry Pi
How to run PiAware and still use the RPI for other things also?
Guide to install PiAware on Raspberry Pi 4
Changing Piaware Settings Without SSH and Without microSD Card plugged in Desktop
Succesfully shared ADB-B Flight feed to Flightradar24
DHCP Issues
Keeping feeder ID on new install
Multilateration (MLAT): Supported / Receiver location not configured
Graphs for dump1090 -- my version with install script
Site local IP address change with new Pi
PlanePlotter Support And FlightAware
3.5.3 SD card failed on Rpi had to do fresh build and have issues in account
WiFi Modem change
Mlat keeps stopping
Mlat keeps stopping
Please need help again
Can't get dump 978 working
Unique Identifier transfer to new install
Feed data to PiAware in AVR Format from External ADS-B Receiver
Ip address wrong on my Feed Page
Dump978-fa intermittent
Unable to find wireless network after enabling updates
3.7.1 upgrade failure
Running ADBS 6.0 trying to update to 8.2
Problems with update to 3.7.1
How to find your feeder-id (Unique Identifier) if you see “No Such ADSB Site” at https://flightaware.com/adsb/stats/user/, even when you are logged-in to your Flightaware account?
  1. Go to page https://flightaware.com/adsb/piaware/claim
  2. You may see a new feeder id listed under heading “Success!
    You claimed the following 1 receivers”
  3. You will also see a list of all old/rexisting feeder id under heading “Linked PiAware Receivers”.
  4. Choose the station number you want to use, and copy its Unique ID (feeder-id)
Thanks @abcd567, will bookmark that one. Also will be considering backing up/ cloning SD cards.
@biekerc
Thanks for correcting typo in the title of thread :slightly_smiling_face:
Is this done through putty?
Yes, PuTTY is used for following two commands:
(Replace xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx by your actual feeder-id / UUID )
Im afraid im not to smart with putty.
Ok, do this:
  1. Power-off RPi, slip out microSD card, slip into card reader, and plug the card reader to your desktop/laptop.
  2. In File explorer / File manger of desktop/laptop, double click on the drive letter of microSD card. You will see many files. One of these is named piaware-config.txt. Open this file, scroll-down to bottom, and at bottom add following line:
  3. Save the file piaware-config.txtafter adding this line.
  4. Eject the mocroSD card, slip out from card reader, slip into RPi, and power-up.
  5. Wait for 5 minutes, then while logged-in to Flightaware, click this link, and see if all buttons are green.
Do you even have a feeder-id? If not it will not help you in claiming your pi.
How do I do this without having the device booted up with the new install?
Will it work editing the piaware-config.txt via PC after the image has been written to it?
I’m thinking about reimage on a new SD and then start over, but with the same feeder
And i do not have a screen/mouse/keyboard which i can connect to the Raspi.
Why wouldn’t it? Why even have a config file if it doesn’t work?
Also you could read the post 3 posts up.
That’s why i was asking. Thought by myself “it should work”, but wanted to be sure.
And to answer your question:
I’ve seen installations of different applications which simply overwrite the config on first launch, even if you have entered data already
I should have read the instructions first…
There is documented how to enable WiFi on a fresh install before booting. This is also not overwritten…
Sorry for stupidity
Grrrr!!! Wish I had noticed this post before I updated my Pi and somehow messed it up. Lost 2-3 years of info after I reimaged to a Raspberry Pi 2 which gave me a new ID. Didn’t know how to change the feeder info and deleted the ‘old’ info
Ah Well. Just have to start again but the new version 3.8.1 doesn’t quite seem to be playing ball as dump1090 seems to be stopping every so often. Will post as a new topic
Declan
Wish I had found this before I just reimaged my card after 3.8.1 stopped working and wasn’t updating for a month. Oh well, I’ve already removed the old site from my account.
I can’t write the ID in any way. Does anyone know why?
That’s not a piaware sd-card image and you haven’t installed the add-on version of piaware either.
PiAware - dump1090 ADS-B integration with FlightAware - FlightAware
This is the screen after the device restarts.
But I can see the planes on the local ip.
seem to be that you have dump1090 installed, but not piaware.
Piaware is required to upload the receiver data to Flightaware.
Another evidence is your screenshot where you are not able to restart piaware.
To install it, check the step 2 in the official documentation:
Another indication of piaware data feeder not installed (or installed, but not configured with a feeder-id) is that the SkyView map lacks the station marker and the range rings, like this:
