For Beginners - How to Get Back Existing Station Number in A Fresh Install
OK Thanks Much Lesson Learned back up and running!
Thanks for the reply , however it would seem that I have a bigger problem than I than I first thought.
sudo piaware-config feeder -id (UNIQUE ID NUMBER copied and pasted)
sudo: piaware-config: command not found
I don’t think you want to have a space between ‘feeder’ and ‘-id’. It’s been a while, so I could very well be wrong, but I think you are looking for it to be ‘feeder-id’.
Or, in your example, “sudo piaware-config feeder-id (UNIQUE ID NUMBER copied and pasted)”
Give that a try.
Thanks for the tutorial @abcd567 I was able to reassociate my existing base station using the steps but now a new station was created and is active along side my reclaimed one. Is there a way I can make the duplicate station running off the same RaspberryPi inactive or force delete it from my account? Thanks for the help!
you can remove the unused station from your account after 24 hrs of inactivity of that specific station via the settings page.
(1) Go to stats page.
https://flightaware.com/adsb/stats/user/
(2) From dropdown, select the station yo want to delete, then click gear icon at top-right
(3) Scroll down to find “Edit Location” setting. Below that you will see the link to delete the site. This link will be available only when that site is inactive for 24 hrs or more.
