Piaware feeder-id
For Beginners - How to GetBack Existing StationNumber in A Fresh Install
Also see this thread:
Howto : Piaware SD card image 3.8.0 QuickstartGuide
Note: Above Howto is for ver 3.8.0 but applicable to ver 3.8.1, except that the link to download image is for outdated image ver 3.8.0, so dont use that link. Instead download latest imahe from Flightaware page:
https://flightaware.com/adsb/piaware/build
FR24 key
You can copy-paste fr24key in Notepad and save notepad, using following method:
cat /etc/fr24feed.ini
receiver="beast-tcp"
fr24key="xxxxxxxxxxxxxxx"
host="127.0.0.1:30005"
bs="no"
raw="no"
logmode="1"
logpath="/var/log/fr24feed"
mlat="yes"
mlat-without-gps="yes"
Alternate method to get the fr24key
https://discussions.flightaware.com/t/announcing-piaware-3-8-1/59021/141
Planefinder sharecode
SSH to RPi and give following command:
cat /etc/pfclient-config.json
The above command will display following long text. Scroll right. Continue scrolling right till you reach end of text, and the share code will be there at the end.
{"tcp_address":"127.0.0.1","tcp_port":"30005","select_timeout":"10","data_upload_interval":"10","connection_type":"1","aircraft_timeout":"30","data_format":"1","latitude":"xx.xxxx","longitude":"yy.yyyy","sharecode":"zzzzzzzzzzzz"}
