Is it possible to get the performance graphs available from the ADS-B Receiver Project using Dump1090-fa or do I have to use Dump1090-mutability? If it is possible, I would be gratefdul for any instructions/guidance
Apologies if instructions have been posted previously.
Yes, it is available for BOTH dump1090-mutability as well as for dump1090-fa.
When you run the install script, It will offer to
Update system. It actually Upgrades, which is unnecessary. I always say NO to it.
Next it will offer to install (or upgrade) one of the two (dump1090-mutability OR dump10990-fa) say NO as you already have latest version of dump1090-fa.
Next It will offer data feeders. Say NO if you have them
Next it will offer some web storage, say No
Last it will offer Web Portal. This installs Graphs. Say YES to it, and then No to “Advance Options”.
The script will proceed to install Web Portal/Graphs.
Wait for 20 minutes, graphs will appear.
Otherwise give following command to make graphs appear immediately… sudo ~/adsb-receiver/build/portal/graphs/make-collectd-graphs.sh 24h
Strange! Never heard of or faced this problem on Ras Pi / Raspbian. Occasionally this problem occured with Orange Pi board.
It seems your install got broken somehow, and is not fetching data from dump1090. Hard to debug. Maybe some one who faced this problem can come up with a solution.
At me since several month vice versa:
dump1090 graphs: YES
system graphs: NO, tabs are empty
after first installation system graphs worked for some weeks, then stopped …
Hardware: RasPi 2 Model B
OS: Raspbian GNU/Linux 8 (jessie) // FW: #1014
I reinstalled ADSB project several times, no success, still the same: only dump1090 graphs visible … same phenomenon on my second RasPi (Pi 3 Model B, jessie, #1028)
Any suggestions for a solution ? Thanks in advance …
Yesterday I tried to upgrade from jessie to stretch as described, everything went well, but via Putty and WinSCP no access anymore. !
A warning message on my putty popped up, something with decryption … (I forgot) …result: no connection …
So I turned back and put put a SD-Card with an image of a functinable jessie and all dump1090 stuff in my RasPi.
two things to note for stretch.
a. must enable ssh by putting a file named ssh in the boot folder (fat32 accessible from PC)
b. use a strong password of at least 8 characters.
Installed v0.70, upgraded from jessie to stretch: system works fine, have access via putty an WinSCP, no nned for a blank file named ssh,
but: still no system graphs visible …
As already announced, I will try with a fresh SD card with stretch installed …
yes, according to ==> datenreise
but during update/upgrade some failures occured. So I have to add “-y” and/or “–force-yes” and I had to install manually “php7.0”.
Now everything works, systems graphs too, except “Bandwidth Usage (wlan0)” …
