I installed 3.7.1 the other day and had an old 978 SDR laying around from a stratux build.
I ran the following commands from the directions:
sudo apt update
sudo apt install rtl-sdr
sudo systemctl stop piaware dump1090-fa dump978-fa
then
unplugged the 978 and did
rtl_eeprom -s 00001090
unplugged, replugged the 1090 and started over with the above, then ran
rtl_eeprom -s 0000978
all returned OK
I then went to the quick start guide and ran
sudo piaware-config uat-receiver-type sdr
sudo piaware-config rtlsdr-device-index 00001090
sudo piaware-config uat-sdr-device driver=rtlsdr,serial=00000978
sudo reboot
here are my status returns
Loaded: loaded (/lib/systemd/system/piaware.service; enabled)
Active: active (running) since Wed 2019-05-29 18:53:27 UTC; 3min 49s ago
Main PID: 499 (piaware)
├─ 499 /usr/bin/piaware -p /run/piaware/piaware.pid -plainlog -sta...
├─ 643 /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost...
└─1000 /usr/lib/piaware/helpers/fa-mlat-client --input-connect loc...
May 29 18:54:33 piaware sudo[991]: pam_unix(sudo:session): session closed f...ot
May 29 18:54:33 piaware piaware[499]: Starting multilateration client: /usr...94
May 29 18:54:34 piaware piaware[499]: piaware has successfully sent several...e!
May 29 18:54:34 piaware piaware[499]: mlat-client(1000): fa-mlat-client 0.2...up
May 29 18:54:34 piaware piaware[499]: mlat-client(1000): Using UDP transpor...51
May 29 18:54:34 piaware piaware[499]: mlat-client(1000): Listening for Beas...05
May 29 18:54:34 piaware piaware[499]: mlat-client(1000): Listening for Exte...06
May 29 18:54:34 piaware piaware[499]: mlat-client(1000): Input connected to...05
May 29 18:54:34 piaware piaware[499]: mlat-client(1000): Input format chang...ck
May 29 18:54:34 piaware piaware[499]: mlat-client(1000): Beast-format resul...ed
Hint: Some lines were ellipsized, use -l to show in full.
pi@piaware:~$
and
pi@piaware:~$ sudo systemctl status dump1090-fa
Loaded: loaded (/lib/systemd/system/dump1090-fa.service; enabled)
Active: active (running) since Wed 2019-05-29 18:53:27 UTC; 4min 14s ago
Main PID: 491 (dump1090-fa)
└─491 /usr/bin/dump1090-fa --net-bo-port 30005 --fix --device-inde...
May 29 18:53:27 piaware systemd[1]: Starting dump1090 ADS-B receiver (Fligh.....
May 29 18:53:27 piaware systemd[1]: Started dump1090 ADS-B receiver (Flight...).
May 29 18:53:27 piaware dump1090-fa[491]: Wed May 29 18:53:27 2019 UTC dump....
May 29 18:53:27 piaware dump1090-fa[491]: rtlsdr: using device #0: Generic R...)
May 29 18:53:28 piaware dump1090-fa[491]: Found Rafael Micro R820T tuner
May 29 18:53:28 piaware dump1090-fa[491]: rtlsdr: enabling tuner AGC
and
pi@piaware:~$ sudo systemctl status dump978-fa
● dump978-fa.service
Loaded: not-found (Reason: No such file or directory)
Active: inactive (dead)
pi@piaware:~$ rtl_test -t
Found 2 device(s):
0: Realtek, RTL2832U, SN: 00001090
1: Realtek, RTL2838UHIDIR, SN: 00000978
usb_claim_interface error -6
Failed to open rtlsdr device #0.
It seems the serial numbers assigned correctly, but it isn't starting dump978. Any ideas what I missed? It has to be something dumb. Sorry, don't know why the forum is formatting my post the way it is.
Also, when I try to go to IPaddress/8080 I get a 404 not found page, so it's like it just didn't install the packages? Perhaps my 978 SDR simply isn't compatible? It's one of these: https://www.amazon.com/Stratux-1090ES-UAT-Radio/dp/B01ENU1DQC/ref=sr_1_16?keywords=978+sdr&qid=1559156631&s=gateway&sr=8-16
pi@piaware:~$ sudo journalctl --no-pager -u lighttpd
– Logs begin at Wed 2019-05-29 18:53:17 UTC, end at Wed 2019-05-29 19:10:19 UTC. –
May 29 18:53:26 piaware systemd[1]: Starting Lighttpd Daemon…
May 29 18:53:27 piaware lighttpd[372]: Syntax OK
May 29 18:53:27 piaware systemd[1]: Started Lighttpd Daemon.
pi@piaware:~$ sudo journalctl --no-pager -u dump978-fa
– Logs begin at Wed 2019-05-29 18:53:17 UTC, end at Wed 2019-05-29 19:10:54 UTC. –
pi@piaware:~$
Easiest would be to rewrite the sd-card with the current image from flightaware and just copy over your piaware-config.txt. (save before writing the image)
Then put in your feeder-id and you should have everything installed and running again.
(For Beginners - How to Get Back Existing Station Number in A Fresh Install)
Alternatively you can try to install the missing packages:
dump978-fa.service - dump978 ADS-B UAT receiver
Loaded: loaded (/lib/systemd/system/dump978-fa.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2019-05-30 15:11:09 UTC; 4min 23s ago
Main PID: 1117 (dump978-fa)
CGroup: /system.slice/dump978-fa.service
└─1117 /usr/bin/dump978-fa --sdr driver=rtlsdr,serial=00000978 --raw-port 30978 --json-port 30979
May 30 15:11:10 piaware dump978-fa[1117]: Found Rafael Micro R820T tuner
May 30 15:11:10 piaware dump978-fa[1117]: Reattached kernel driver
May 30 15:11:11 piaware dump978-fa[1117]: Detached kernel driver
May 30 15:11:11 piaware dump978-fa[1117]: Found Rafael Micro R820T tuner
May 30 15:11:11 piaware dump978-fa[1117]: Exact sample rate is: 2083333.135571 Hz
May 30 15:11:11 piaware dump978-fa[1117]: [R82XX] PLL not locked!
May 30 15:11:11 piaware dump978-fa[1117]: SoapySDR: using maximum manual gain 49.6 dB
May 30 15:11:11 piaware dump978-fa[1117]: SoapySDR: using stream setting buffsize=262144
May 30 15:11:19 piaware dump978-fa[1117]: [::]:30978: accepted a connection from [::1]:39608
May 30 15:11:39 piaware dump978-fa[1117]: [::]:30978: accepted a connection from [::1]:39610
No messages received yet, so either no one is flying on a UAT transponder in range, or the receiver is bad. Could go either way. I used this receiver for a stratux box and IIRC, I stopped using it because it was flaky, but it could have been the 1090 receiver, can’t remember.
