I hove both dongles on my Raspberry pi. I have serialized both. The blue pro stick 1090 is 00001090 and the orange UAT 978 stick is 00000978. DUMP1090-fa is running just fine. But DUMP978-fa seems to be have an issue. Any help would be appreciated.
pi@piaware:~ $ rtl_test -t
Found 2 device(s):
0: Realtek, RTL2832U, SN: 00001090
1: Realtek, RTL2832U, SN: 00000978
usb_claim_interface error -6
Failed to open rtlsdr device #0.
pi@piaware:~ $
pi@piaware:~ $ sudo systemctl status piaware
Loaded: loaded (/lib/systemd/system/piaware.service; enabled; vendor preset:
Active: active (running) since Sun 2019-10-27 22:44:18 UTC; 2min 7s ago
Main PID: 413 (piaware)
├─413 /usr/bin/piaware -p /run/piaware/piaware.pid -plainlog -statusf
├─622 /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost --n
└─831 /usr/lib/piaware/helpers/fa-mlat-client --input-connect localho
Oct 27 22:45:12 piaware piaware[413]: mlat-client(831): fa-mlat-client 0.2.10 st
Oct 27 22:45:12 piaware piaware[413]: mlat-client(831): Using UDP transport to 7
Oct 27 22:45:12 piaware piaware[413]: mlat-client(831): Listening for Beast-form
Oct 27 22:45:12 piaware piaware[413]: mlat-client(831): Listening for Extended B
Oct 27 22:45:12 piaware piaware[413]: mlat-client(831): Input connected to local
Oct 27 22:45:12 piaware piaware[413]: mlat-client(831): Input format changed to
Oct 27 22:45:12 piaware piaware[413]: mlat-client(831): Beast-format results con
Oct 27 22:45:55 piaware sudo[1454]: piaware : TTY=unknown ; PWD=/ ; USER=root ;
Oct 27 22:45:55 piaware sudo[1454]: pam_unix(sudo:session): session opened for u
Oct 27 22:45:55 piaware piaware[413]: no ADS-B data program seen listening on po
lines 1-20/20 (END)…skipping…
├─413 /usr/bin/piaware -p /run/piaware/piaware.pid -plainlog -statusfile /run/piaware/status.json
├─622 /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost --net-bo-port 30005 --stdout --lat 43.024 --lon -84.179
└─831 /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --resul
Oct 27 22:45:12 piaware piaware[413]: mlat-client(831): fa-mlat-client 0.2.10 starting up
Oct 27 22:45:12 piaware piaware[413]: mlat-client(831): Using UDP transport to 70.42.6.191 port 7304
Oct 27 22:45:12 piaware piaware[413]: mlat-client(831): Listening for Beast-format results connection on port 30105
Oct 27 22:45:12 piaware piaware[413]: mlat-client(831): Listening for Extended Basestation-format results connection on port 30106
Oct 27 22:45:12 piaware piaware[413]: mlat-client(831): Input connected to localhost:30005
Oct 27 22:45:12 piaware piaware[413]: mlat-client(831): Input format changed to BEAST, 12MHz clock
Oct 27 22:45:12 piaware piaware[413]: mlat-client(831): Beast-format results connection with ::1:30104: connection established
Oct 27 22:45:55 piaware sudo[1454]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/netstat --program --tcp --wide --all --numeric
Oct 27 22:45:55 piaware sudo[1454]: pam_unix(sudo:session): session opened for user root by (uid=0)
Oct 27 22:45:55 piaware piaware[413]: no ADS-B data program seen listening on port 30978 for 90 seconds, next check in 60s
[1]+ Stopped sudo systemctl status piaware
pi@piaware:~ $ sudo systemctl status dump1090-fa
Active: active (running) since Sun 2019-10-27 22:44:18 UTC; 2min 49s ago
Main PID: 410 (dump1090-fa)
└─410 /usr/bin/dump1090-fa --net-bo-port 30005 --fix --device-index 00001090 --gain -10 --ppm 0 --max-range 360 --net --net-heartbeat 60 --net-ro-s
Oct 27 22:44:18 piaware systemd[1]: Started dump1090 ADS-B receiver (FlightAware customization).
Oct 27 22:44:19 piaware dump1090-fa[410]: Sun Oct 27 22:44:19 2019 UTC dump1090-fa 3.7.2 starting up.
Oct 27 22:44:19 piaware dump1090-fa[410]: rtlsdr: using device #0: Generic RTL2832U (Realtek, RTL2832U, SN 00001090)
Oct 27 22:44:19 piaware dump1090-fa[410]: Found Rafael Micro R820T tuner
Oct 27 22:44:20 piaware dump1090-fa[410]: rtlsdr: enabling tuner AGC
[2]+ Stopped sudo systemctl status dump1090-fa
pi@piaware:~ $ sudo systemctl status dump978-fa
● dump978-fa.service - dump978 ADS-B UAT receiver
Loaded: loaded (/lib/systemd/system/dump978-fa.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Sun 2019-10-27 22:47:30 UTC; 359ms ago
Process: 1561 ExecStart=/usr/share/dump978-fa/start-dump978-fa (code=exited, status=1/FAILURE)
Main PID: 1561 (code=exited, status=1/FAILURE)
Oct 27 22:47:30 piaware systemd[1]: dump978-fa.service: Main process exited, code=exited, status=1/FAILURE
Oct 27 22:47:30 piaware systemd[1]: dump978-fa.service: Unit entered failed state.
Oct 27 22:47:30 piaware systemd[1]: dump978-fa.service: Failed with result ‘exit-code’.
