I have been running a dump1090 for some time now and I just added a radio for UAT978. I followed the instructions on one of the discussion pages and entered the following commands after I plugged the orange flightaware receiver into the Pi.
Piaware starts but neither the 1090 or 978 comes up.
Here is what I get with the status inquiry
pi@piaware:~$ sudo systemctl status piaware -l
â—Ź piaware.service - FlightAware ADS-B uploader
Loaded: loaded (/lib/systemd/system/piaware.service; enabled)
Active: active (running) since Fri 2020-11-13 20:35:16 UTC; 8min ago
Main PID: 516 (piaware)
└─516 /usr/bin/piaware -p /run/piaware/piaware.pid -plainlog -statusfile /run/piaware/status.json
Nov 13 20:42:31 piaware sudo[1411]: pam_unix(sudo:session): session closed for user root
Nov 13 20:42:31 piaware piaware[516]: no ADS-B data program seen listening on port 30005 for 70 seconds, next check in 60s
Nov 13 20:42:37 piaware sudo[1420]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/netstat --program --tcp --wide --all --numeric
Nov 13 20:42:37 piaware sudo[1420]: pam_unix(sudo:session): session opened for user root by (uid=0)
Nov 13 20:42:37 piaware sudo[1420]: pam_unix(sudo:session): session closed for user root
Nov 13 20:42:37 piaware piaware[516]: no ADS-B data program is serving on port 30005, not starting multilateration client yet
Nov 13 20:43:31 piaware sudo[1477]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/netstat --program --tcp --wide --all --numeric
Nov 13 20:43:31 piaware sudo[1477]: pam_unix(sudo:session): session opened for user root by (uid=0)
Nov 13 20:43:31 piaware sudo[1477]: pam_unix(sudo:session): session closed for user root
Nov 13 20:43:31 piaware piaware[516]: no ADS-B data program seen listening on port 30005 for 130 seconds, next check in 60s
pi@piaware:~$
Nov 13 20:44:55 piaware systemd[1]: Unit dump1090-fa.service entered failed state.
pi@piaware:~$
pi@piaware:~$ sudo systemctl status dump978-fa
â—Ź dump978-fa.service
Loaded: not-found (Reason: No such file or directory)
Active: inactive (dead)
pi@piaware:~$
