Hi all,
New install on clean pi. Two problems I cannot seem to fix.
1: My 978-sdr is being used by dump1090-fa regardless of what I put in rtlsdr-device-index. I would like use to my 1090-sdr for the 1090 band for the better antenna reception. I have tried inputting the serial number in rtlsdr-device-index as well with no change.
Using device 0: Generic RTL2832U OEM
usb_claim_interface error -6
Failed to open rtlsdr device #0.
This file configures piaware and related software.
You can edit it directly or use piaware-config from the command line
to view and change settings.
If /boot/piaware-config.txt also exists, then settings present in
that file will override settings in this file.
allow-manual-updates yes # updated by fa_piaware_config
uat-receiver-type sdr # updated by fa_piaware_config
receiver-type rtlsdr # updated by fa_piaware_config
rtlsdr-device-index 1 # updated by fa_piaware_config
rtlsdr-gain max # updated by fa_piaware_config
rtlsdr-ppm 75 # updated by fa_piaware_config
allow-modeac yes # updated by fa_piaware_config
use-gpsd yes # updated by fa_piaware_config
rfkill yes # updated by fa_piaware_config
uat-sdr-device driver=rtlsdr,serial=stx:978:68 # updated by fa_piaware_config
uat-sdr-gain max # updated by fa_piaware_config
uat-sdr-ppm 68 # updated by fa_piaware_config
feeder-id 7bf5791e-e0f1-49ea-b371-ef7c5760063e # updated by fa_piaware_config
wired-network yes # updated by fa_piaware_config
wired-address 192.168.1.209 # updated by fa_piaware_config
dump978 is not running and I am not sure why.
PiAware master process (piaware) is running with pid 498.
PiAware ADS-B client (faup1090) is running with pid 567.
PiAware ADS-B UAT client (faup978) is not running.
PiAware mlat client (fa-mlat-client) is running with pid 588.
Local ADS-B receiver (dump1090-fa) is running with pid 497.
Local ADS-B UAT receiver (dump978) is not running.
dump1090-fa (pid 497) is listening for ES connections on port 30005.
no program appears to be listening for UAT connections on port 30978.
faup978 is NOT connected to the ADS-B UAT receiver.
got ‘couldn’t open socket: connection refused’
dump978 is NOT producing data on localhost:30978.
Your feeder ID is 7bf5791e-e0f1-49ea-b371-ef7c5760063e (configured at /etc/piaware.conf:19)
I installed piaware on a running but clean pi. using PiAware - dump1090 ADS-B integration with FlightAware - FlightAware. It does not seem to matter what i put in the piaware-config it runs the 978 sdr in dump1090. I replaced the commands as you described and still get:
pi@piaware:~ $ sudo piaware-status
PiAware master process (piaware) is running with pid 495.
PiAware ADS-B client (faup1090) is running with pid 565.
PiAware mlat client (fa-mlat-client) is running with pid 586.
Local ADS-B receiver (dump1090-fa) is running with pid 494.
dump1090-fa (pid 494) is listening for ES connections on port 30005.
pi@piaware:~ $ sudo rtl_test -d 0 Found 2 device(s):
0: Realtek, RTL2838UHIDIR, SN: stx:978:68
1: Realtek, RTL2838UHIDIR, SN: stx:1090:75
pi@piaware:~ $
It seems to me 978 is mostly supported via the piaware sd-card image …
There shoudl also be documentation or a warning if you use piaware-config options that don’t do anything while using the package install.
