The installation of dump1090-fa installs lighttpd also.
Lighttpd is necessary to display map of dump1090-fa.
Unfortunately in Pi24, lighttpd FAILS on reboot, causing map problem
The Pi24 image has a tmpfs entry for /var/log folder in it’s /etc/fstab file.
This entry causes deletion of contents of /var/log folder on reboot.
The lighttpd for some reason is unable to re-create it’s log file on reboot and crashes.
Details and workaround are here, if you are interested to see.
How to Feed Data to Multiple Sites - A Brief Guide
Best and clean options, which do not require any workaround, are as follows:
OPTION-1
Download and write Piaware SD card img from PiAware - build your own ADS-B ground station for integration with FlightAware - FlightAware (scroll down to “2 - Install PiAware on your SD card”)
Install FR24 feeder by bash script from here Share your ADS-B data - Real-time flight tracker | Flightradar24
OPTION-2
Download and write Raspbian Stretch Lite img from https://www.raspberrypi.org/downloads/raspbian/,
Install Piaware data feeder+dump1090-fa from PiAware - dump1090 ADS-B integration with FlightAware - FlightAware
See here for detais:
Bake a Pi
