I have been feeding data to FA using the standard install dump1090-fa on a Pi, and also feeding FR24 from dump1090-fa. However, a few weeks ago on one of my Pis, the FR24 feeder stopped whilst my two other Pis are fine. I’ve read various things on other forums about problems with a new FR24 feeder and dump1090 mutability but nothing about dump1090-fa
Could anyone simply suggest how I might resolve this problem? The Pi is running Raspbian Stretch.
One of my Pi had dump1090-fa, and other dump1090-mutability ver 1.15~dev.
The dump1090-fa one is working ok even after upgrades of fr24feed.
The dump1090-mutability one failed as the fr24feed upgrade changed permissions and ownerships of dump1090-mutability files and folders. I had to format microSD card and make a fresh install, first dump1090-mutability ver 1.15 ~dev, then the latest version of FR24 feeder by bash script given on their site.
Thanks. I’m using dump1090-fa on two Pis, one is still feeding FR24 the other failed. I was going to install the FR24 feeder software again but was worried I would create problsm after reading about dump1090-mutability
Setting on both Pis are identical - both running the same version of FR24 feeder. The only difference is that the one that isn’t working is using Rasbian Stretch
What are settings in /etc/fr24feed.ini ?
if receiver="dvbt"
change it to receiver="avr-tcp" host="127.0.0.21:30002"
Make sure to use 127.0.0.1, and not localhost
All your settings and versions are OK. The “Receiver : down …” is caused if dump1090-fa is not working. Are you sure dump1090-fa is working? Please check.
I checked mine on STRETCH, and got output as follows
pi@raspberrypi:~ $ sudo systemctl status dump1090-fa -l
Active: active (running) since Sat 2018-02-03 15:21:54 EST; 1h 35min ago
Main PID: 453 (dump1090-fa)
└─453 /usr/bin/dump1090-fa --device-index 0 --gain -10 --ppm 0 --net-bo-port 30005 --max-range 360 --net --net-heartbeat
Feb 03 15:21:54 raspberrypi systemd[1]: Started dump1090 ADS-B receiver (FlightAware customization).
Feb 03 15:21:54 raspberrypi dump1090-fa[453]: Sat Feb 3 15:21:54 2018 EST dump1090-fa 3.5.3 starting up.
Feb 03 15:21:54 raspberrypi dump1090-fa[453]: rtlsdr: using device #0: Generic RTL2832U (Realtek, RTL2832U, SN 00001003)
Feb 03 15:21:54 raspberrypi dump1090-fa[453]: Detached kernel driver
Feb 03 15:21:55 raspberrypi dump1090-fa[453]: Found Rafael Micro R820T tuner
Feb 03 15:21:55 raspberrypi dump1090-fa[453]: rtlsdr: enabling tuner AGC
pi@raspberrypi:~ $ sudo systemctl status piaware -l
Active: active (running) since Sat 2018-02-03 16:02:10 EST; 54min ago
Main PID: 29021 (piaware)
├─29021 /usr/bin/piaware -p /run/piaware/piaware.pid -plainlog -statusfile /run/piaware/status.json
├─29073 /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost --net-bo-port 30005 --stdout --lat 43.5 --lon -79.6
└─29082 /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,con
Feb 03 16:37:46 raspberrypi piaware[29021]: 4531 msgs recv'd from dump1090-fa (579 in last 5m); 4531 msgs sent to FlightAware
Feb 03 16:42:46 raspberrypi piaware[29021]: 5186 msgs recv'd from dump1090-fa (655 in last 5m); 5186 msgs sent to FlightAware
Feb 03 16:47:16 raspberrypi piaware[29021]: mlat-client(29082): Receiver status: connected
Feb 03 16:47:16 raspberrypi piaware[29021]: mlat-client(29082): Server status: synchronized with 107 nearby receivers
Feb 03 16:47:16 raspberrypi piaware[29021]: mlat-client(29082): Receiver: 110.6 msg/s received 36.9 msg/s processed (33%)
Feb 03 16:47:16 raspberrypi piaware[29021]: mlat-client(29082): Server: 0.2 kB/s from server 0.0kB/s TCP to server 0.5kB
Feb 03 16:47:16 raspberrypi piaware[29021]: mlat-client(29082): Results: 104.4 positions/minute
Feb 03 16:47:16 raspberrypi piaware[29021]: mlat-client(29082): Aircraft: 12 of 36 Mode S, 12 of 12 ADS-B used
Feb 03 16:47:46 raspberrypi piaware[29021]: 5846 msgs recv'd from dump1090-fa (660 in last 5m); 5846 msgs sent to FlightAware
Feb 03 16:52:46 raspberrypi piaware[29021]: 6477 msgs recv'd from dump1090-fa (631 in last 5m); 6477 msgs sent to FlightAware
I just wanted to mention that it works fine on Jessie for me. Version is 1.0.19-13.
Let me ask help on another matter. Installed dump1090-muta 1.15 dev on another Pi (Stretch), it doesn’t seem to get any data. Connected the same dvb-t dongle that currently feeds FA, FR24 etc but still no enjoy. Any tips on what I need to check? Possibly incorrect installation as IP/dump1090/gmap.html doesn’t load map either? Log shows it sees the dongle
Tue Feb 6 09:22:44 2018 UTC dump1090-mutability v1.15~dev starting up.
Using sample converter: UC8, integer/table path
Found 1 device(s):
0: Generic, RTL2832U, SN: 7xxxxxxxxxxxxxx (currently selected)
Max available gain is: 49.60 dB
Setting gain to: 49.60 dB
Gain reported by device: 49.60 dB
to make the fr24 feeder producing data for other feeders your have to go to localhost:8754 and settings and put: –net --net-http-port 8080 in the process arguments and save and restart.
This works for me, before that piaware complains about that dump1090 is not producing data on localhost:3005.
