Here’s a heads-up after I found my RPi unresponsive this morning to anything dump1090-mutability related, e.g. PiAware Skyview showing “AJAX call failed (error: Not Found)”.
The thread above at the FR24-forum will provide you with the issue and possible solutions / workarounds.
Basically it means the fr24feed-installer will alter the owner on /run/dump1090-mutability to nobody:nogroup where the owner should be dump1090 in my case (and probably in yours too).
Quick fix: chown -R dump1090:nogroup /run/dump1090-mutability.
Besides that, with this new version lots of fr24feed-logging went into daemon.log and syslog, even with logmode="0". To prevent exhaustive writing to the disk, I’ve cut this short with an extra file /etc/rsyslog.d/fr24feed.conf reading
if $programname == 'fr24feed' then /dev/null
& stop
Above post is applicable if your install had dump1090-mutability.
For my Piaware SD Card image with dump1090-fa, I noted following after auto upgrade to fr24feed ver 1.0.19-2 and version 1.0.19-5:
There was no problem of "Ajax call failed. The Skyview map displayed OK.
The page ip-of-pi:8754 and ip-of-pi:8754/settings.html will not load sayaing “Problem loading page. Unable to connect”.
status of fr24feed is failed:
pi@piaware:~$ fr24feed-status
[FAIL] FR24 Feeder/Decoder Process ... failed!
Add line sudo systemctl restart fr24feed above last single-worded line (i.e. above exit0)
The file will become like this:
#!/bin/sh -e
# By default this script does nothing.
exit 0
Save file (Ctrl+o) and close file (Ctrl+x)
Reboot
sudo reboot
After reboot, check status
[ ok ] FR24 Feeder/Decoder Process: running.
[ ok ] FR24 Stats Timestamp: 2018-01-20 20:04:36.
[ ok ] FR24 Link: connected [TCP].
[ ok ] FR24 Radar: T-CYYZ9.
[ ok ] FR24 Tracked AC: 43.
[ ok ] Receiver: connected (52092 MSGS/0 SYNC).
[ ok ] FR24 MLAT: ok [UDP].
[ ok ] FR24 MLAT AC seen: 41.
Fix 2 of 2
The page ip-of-pi:8754 and ip-of-pi:8754/settings.html will start displaying after Fix 1, but from settings page, the “Save” and “Restart” buttons are missing, and instead there is a remark “Config file is open in read-only mode and cannot be modified from within the application.”
Give following command, then reboot.
sudo chmod a+rw /etc/fr24feed.ini
sudo reboot
After reboot load page ip-of-pi:8754/settings.html and you will see the “Save” and “Restart” buttons.
If these buttons still dont appear, clear browser cache (Ctrl+Shift+Delete) and Reload Browser (Ctrl+F5).
