This is a bit confusing for a new user with PI24 image. Better not use it.
Here are straightforward simple steps for Flightradar24’s Pi24 image:
(1) If you want to use multiple site, the very first step you have to do is to open your web browser, go to address ip=of-pi:8754/settings.html
and add config parameter --net
in “Process Arguments” field. Please see blue circle in settings below:
Click Save and Restart buttons located at bottom-right of settings page.
(2) To make sure your changes in step (1) are saved and applied, open browser and go to address ip-of-pi:30005
. Wait for a while, and if your settings are OK and saved, you will see this:
(3) If you see as in step (2) above, you are set to add other feeders. Proceed to step (4). If you cant see above, then your settings are not saved due to a bug in Pi24 image. SSH to Pi and issue following command:
sudo nano /etc/fr24feed.ini
Scroll down to find this line
procargs="--gain -10"
add --net
to it so it becomes
procargs="--net --gain -10"
Note: if line starting with procargs=
does not exist, scroll down and below last line add following new line:
Save (Ctrl+O) and close (Ctrl+X)
Restart fr24feed
sudo systemctl restart fr24feed
Now repeat test in step (2) above.
(4) Add PIAWARE
wget https://flightaware.com/adsb/piaware/files/packages/pool/piaware/p/piaware-support/piaware-repository_3.8.1_all.deb
sudo dpkg -i piaware-repository_3.8.1_all.deb
sudo apt-get update
sudo apt-get install piaware
(5) Add PLANEFINDER
wget http://client.planefinder.net/pfclient_4.1.1_armhf.deb
sudo dpkg -i pfclient_4.1.1_armhf.deb
(6) Above instructions are sufficient. However for details and further reading, you may see these posts:
(a) installing other feeders on Pi24 image
https://forum.flightradar24.com/forum/radar-forums/flightradar24-feeding-data-to-flightradar24/12435-2019-pi24-image-quickstart-guide?p=156015#post156015
(b) 2019 - PI24 (Image) QuickStart Guide
(c
) Raspberry Pi:How To Install Raspian OS + Dump1090 + FR24 Data Feeder
https://forum.flightradar24.com/forum/radar-forums/flightradar24-feeding-data-to-flightradar24/8804-raspberry-pi-how-to-install-raspian-os-dump1090-fr24-data-feeder
