Hello,
I reinstalled tar1090 yesterday. Everything works fine too. Only now I no longer have the maximum range on the map. Where can I activate it?
Greetings Alex
Hello,
Greetings Alex
This link should take you to the relevant part of the TAR1090 documentation:
Hello Lawrence Hill,
I expressed myself wrong. I’m not looking for a static circle. tar1090 should show me the max position of the plane dynamically on the map. It worked before… I didn’t install anything else on the Pi except the update. Oh yes: I know the sides of “wiedehopf”…
Greetings Alex
Addendum: this is how it should look like:
Which decoder are you using? dump1090-fa or readsb?
The actual range plot only works if you are using readsb.
I additionally installed the package and it works. Thanks… ![]()
The last question for today: ![]()
In which config-file can I manually change the gain?
Alex
The config file is:
/etc/default/readsb
You can also use the helper script to set the gain:
