Which maps will display the coverage that my Piaware has? The coverage usually shows up as a shadow.
I think what I should say is how to display the maximum coverage range/curve.
Look at tar1090, this is an alternative to the original map where you can have two different boundaries.
One your max range based on terrain and the other one based on your current flights the last 7 days
Like this:
Blue is the max range, green the actual range
I have tar1090 installed but how do I activate the the max range?
Dump 1090 Flightaware
follow the instructions on the github pages
I use @Akissack’s excellent OpenLayers3 variant, which is a drop-in html replacement for the standard SkyAware front-end. It’s best suited to the UK because of the custom civilian and military layers included, but you could easily add your own layers and tweak accordingly. It supports range plots overlaid at three different heights.
