Hi all, not a linux programmer at all but, with help, get by. Help!! A bias t V3 dongle script for turning on bias t, after turning off 1090 mutability. V3 script below to turn on bias t:
git clone GitHub - rtlsdrblog/rtl_biast: Bias tee software for the RTL-SDR.com V3 Dongle
cd rtl_biast
mkdir build
cd build
cmake …
make
cd src
./rtl_biast -b 1
If you want to be able to run the bias tee program from anywhere on the command line you can also run “sudo make install”
I can get this working, but, have to go through the laborious task of cd’ing to rtl_sdr then cd build then cd src THEN applying the start script ./rtl_biast -b 1. Now you will note above, the creator does give you the option of the starting script anywhere on the command line by running sudo make install, BUT doesn’t actually show the script.
Can someone help please
