RTL-SDR v3 bias tee power on/off - 3 methods for 3 different installs
(1) Method for dump1090-fa
Originally in 2017 Oliver Jowett (@obj) has proposed a method to turn on bias-t by adding a command in dump1090-fa.service file.
https://discussions.flightaware.com/t/enable-biast-on-rtl-sdr-v3-before-dump-fa-piaware-start/20046/2
Subsequently in mid 2018 (1) Akos and (2) RTL-SDR Blog posted this method on their web pages. Both sites have “Credits” at bottom of their pages, and have given link to @obj’s method.
http://www.radioforeveryone.com/p/piaware-with-rtl-sdr-blog-v3-and-ads-b.html
https://www.rtl-sdr.com/getting-the-v3-bias-tee-to-activate-on-piaware-ads-b-images/
(1) Method for dump1090-mutability ver 1.15~dev
The method posted on the RTL-SDR Blog is applicable to dump1090-fa only.
It does not apply to dump1090-mutability v1.15~dev, as the dump1090-mutability service files ( dump1090-mutability.service ) are automatically generated by systemd-sysv-generator , and all the changes made by user are overwritten at restart / reboot.
However as the systemd-sysv-generator generates dump1090-mutability.service by reading from file `/etc/init.d/dump1090-mutability, in mid 2018 I have added bias-t start and logging script in the init file, and it works OK. Detailed steps are given here:
RTL-SDR V3 Dongle
Enabling Auto Switch-ON of Bias-T in dump1090-mutability v1.15~dev.
(3) Method for Flightradar24’s Pi24 image
In the Pi24 image, the default startup of it’s dump1090-mutability ver 1.14 at boot is blocked by FR24 programmers . It is configured to be started by fr24feed, with all the necessary config parameters supplied by fr24feed, and NOT by init file of dump1090-mut.
Due to above, in mid 2018 I have proposed to add bias-t startup command in fr24feed’s service file (i.e in file fr24feed.service). Detailed steps are given here:
RTl_SDR v3 bias tee power on/off Raspberry pi
abcd567,
Thanks for the post.
I needed a refresher on how to do this.
In the mean time, I’ve had good luck with this:
https://www.ebay.com/itm/Bias-Tee-Operates-from-10MHz-7000MHz-Bias-tee-Bias-T-DC-HDR-12V-or-USB-pwr/283337131917?_trksid=p2485497.m4902.l9144
https://www.rtl-sdr.com/in-testing-customized-drivers-for-rtl-sdr-blog-v3-sdrs/
this could make life a bit easier
SOURCE: https://www.rtl-sdr.com/in-testing-customized-drivers-for-rtl-sdr-blog-v3-sdrs/
It would be nice if the bias-T could be enabled just by having a variable in the dump1090-fa config file, without running external programs.
It should be possible, since it is supported by the rtlsdr-lib.
