I did a test with dump1090-fa on Piaware SD Card image:
Build & used package rtl_biast.
Dongle used was DVB-T, as I do not have RTL-SDR V3, hence cannot check with a Voltmeter.
The success was checked by outputs to log file. The log file showed that the software rtl_biast did get hold of the Dongle under command rtl_biast -b 1
, and then released it for dump1090-fa to use. Finally dump1090-mutability was found working OK (checked by command top).
STEP-1:
Build package rtl_biast
#First installed Packages needed to build and to fulfill dependencies
cd ~/
sudo apt-get install git
sudo apt-get install cmake
sudo apt-get install libusb-1.0
#Now build rtl_biast
git clone https://github.com/rtlsdrblog/rtl_biast
cd ~/rtl_biast
mkdir build
cd build
cmake ..
make
#TEST-1
cd ~/rtl_biast/build/src
./rtl_biast -b 1
usb_claim_interface error -6
#TEST-2
sudo systemctl stop piaware
./rtl_biast -b 1
STEP-2:
Created a script which has two parts.
(a) First part is command to switch on bias-t
/home/pi/rtl_biast/build/src/rtl_biast -b 1
(b) Second part is command to redirect output (stdout + stderr) to a log file biast.log to see what is happening.
> /home/pi/biast.log 2>&1
#Created a new blank script file "biast-switch-on.sh"
sudo nano ~/rtl_biast/build/src/biast-switch-on.sh
#Added following text to newly created blank file
#!/bin/sh
/home/pi/rtl_biast/build/src/./rtl_biast -b 1 > /home/pi/biast.log 2>&1
exit 0
#Saved file (Ctrl+o) and Closed (Ctrl+x)
#Made newly created file executeable
sudo chmod +x ~/rtl_biast/build/src/biast-switch-on.sh
STEP-3:
Created log file biast.log
and made it writeable
touch ~/biast.log
chmod a+rwx ~/biast.log
STEP-4:
Edited file dump1090-fa.service
sudo nano /lib/systemd/system/dump1090-fa.service
In this file, just above the line "ExecStart=/usr/bin/dump1090-fa \"
, ADDED line shown below:
ExecStartPre=/home/pi/rtl_biast/build/src/biast-switch-on.sh
Here is the complete file dump1090-fa.service
AFTER ADDING the line starting with ExecStartPre=
# dump1090-fa service for systemd
[Unit]
Description=dump1090 ADS-B receiver (FlightAware customization)
Documentation=https://flightaware.com/adsb/piaware/
Wants=network.target
After=network.target
[Service]
EnvironmentFile=/etc/default/dump1090-fa
EnvironmentFile=-/var/cache/piaware/location.env
User=dump1090
RuntimeDirectory=dump1090-fa
RuntimeDirectoryMode=0755
$RECEIVER_OPTIONS $DECODER_OPTIONS $NET_OPTIONS $JSON_OPTIONS $PIAWARE_DUMP109$
--write-json /run/dump1090-fa --quiet
Type=simple
Restart=on-failure
RestartSec=30
Nice=-5
[Install]
WantedBy=default.target
STEP-5:
Tested by rebooting, then checking contents of log file ~/biast.log
sudo reboot
#After reboot, check log file
cat ~/biast.log
#BINGO! SUCCESS
STEP-6:
By command top
, checked that dump1090-fa and Piaware are running. FOUND RUNNING OK
top - 03:59:56 up 1 min, 1 user, load average: 0.43, 0.18, 0.06
Tasks: 129 total, 2 running, 127 sleeping, 0 stopped, 0 zombie
%Cpu(s): 11.8 us, 2.7 sy, 0.0 ni, 85.0 id, 0.0 wa, 0.0 hi, 0.5 si, 0.0 st
KiB Mem: 947732 total, 154888 used, 792844 free, 9960 buffers
KiB Swap: 0 total, 0 used, 0 free. 73048 cached Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
657 dump1090 15 -5 25556 6792 2232 S 25.1 0.7 0:16.16 dump1090-fa
394 root 20 0 2352 1248 980 R 23.1 0.1 0:15.54 dump978
393 root 20 0 14736 5356 1488 S 3.6 0.6 0:02.63 rtl_sdr
564 piaware 20 0 19536 6268 3616 S 1.3 0.7 0:01.09 piaware-console
372 root 20 0 97772 6352 5204 S 0.7 0.7 0:00.42 rbfeeder
1013 piaware 20 0 13016 9704 6240 S 0.7 1.0 0:00.55 fa-mlat-client
1021 pi 20 0 5024 2492 2140 R 0.7 0.3 0:00.14 top
7 root 20 0 0 0 0 S 0.3 0.0 0:00.29 rcu_sched
185 root 20 0 0 0 0 S 0.3 0.0 0:00.02 kworker/3:2
227 root 20 0 8032 2728 2472 S 0.3 0.3 0:01.14 systemd-journal
399 root 20 0 2232 1156 1080 S 0.3 0.1 0:00.09 uat2json
488 fr24 20 0 95352 3252 2252 S 0.3 0.3 0:00.23 fr24feed
1 root 20 0 5420 3992 2776 S 0.0 0.4 0:04.01 systemd
