I just purchased the LNA to hook up to my v3 RTL unit. I have followed the directions on this site : Getting the V3 Bias Tee to Activate on PiAware ADS-B Images and every time I try to enable the Bias T i get the below error. Help please
pi@piaware:~/rtl_biast/build $ sudo service dump1090-fa stop && cd ~/rtl_biast/build/src && ./rtl_biast -b 1 && sudo service dump1090-fa start
Found 1 device(s):
0: Realtek, RTL2838UHIDIR, SN: 00000001
Using device 0: Generic RTL2832U OEM
Kernel driver is active, or device is claimed by second instance of librtlsdr.
In the first case, please either detach or blacklist the kernel module
(dvb_usb_rtl28xxu), or enable automatic detaching at compile time.
Tested on freshly written Raspbian Buster WITHOUT installing any version of dump1090
sudo apt update
sudo apt-get install git cmake libusb-1.0
git clone https://github.com/rtlsdrblog/rtl_biast
cd rtl_biast
sudo mkdir build
cd build
sudo cmake ..
sudo make
cd src
./rtl_biast -b 1
Found 2 device(s):
0: Failed to query data
1: Failed to query data
usb_open error -3
Please fix the device permissions, e.g. by installing the udev rules file rtl-sdr.rules
Workaround for usb_open error -3 (missing udev rules)
cd rtl_biast/build/src
./rtl_biast -b 1
Found 2 device(s):
0: Realtek, RTL2832UFA, SN: 00000101
1: Realtek, RTL2838UHIDIR, SN: 00000102
usb_claim_interface error -6
Workaround for usb_claim_interface error -6 (Thanks to @wiedehopf)
cd
sudo rm -rf rtl_biast
cd rtl_biast
sudo mkdir build
cd build
sudo cmake .. -DDETACH_KERNEL_DRIVER=ON
sudo make
cd src
./rtl_biast -b 1
Found 2 device(s):
Detached kernel driver
Reattached kernel driver
Neither was there any rtl-sdr blog v3 dongle connected (I dont have one).
Only FA ProStick (RTL2832UFA, SN: 00000101)
and
RB24 FlightStick (RTL2838UHIDIR, SN: 00000102)
On this RPI, I normally run a microSD card with following (two in one )
2 x Antennas (PCB and Optimized mag-mount)
2 x dongles
2 x dump1090-mutability
2 x piaware (Stations 5252 and 76000)
2 x fr24feed
2 x pfclient
For biast test, I slipped out regular microSD card and slipped in a test microSD card with freshly written Raspbain Buster
thanks @abcd567
btw abcd was using a similar LNA type to yours (some time ago you posted, I think was RCA up to 2GHz input dc 5-15V) with cantenna with good results from 70nm range went up to 120nm, and no filter only the v3.
Thanks for the inspiration abcd I use FR24 image with multiple feeds to other sites and works great until I got the LNA .Tried and tried to enable bias tee without success until I found your post , I still canât do it automatically and have to manually stop all feeders and dump1090 -mutabillity .I can then run the ./rtl_biast -b 1 without getting the -6 error . I set it to always on(bias tee) save config to device ,OK ⌠reconect the dongle and get the green light on the LNA ( I drilled a little hole in the top of the case ove the LED otherwise itâs invisible . * Run ./rtl_biast -b 1 again just to be sure it sys bias tee eneabled âŚYES . Start back up my feeders and dump1090 and all great . Just to check I restarted the PI and back to square one .no bias tee ,no green light no feeders feeding . back to manual stop every thing âŚrun./rtl_biast -b 1 etc etc etc ⌠Any idea why the RTL wonât kepp the on setting ?
pi@GaragePi:~ $ rtl_eeprom -b y
Found 1 device(s):
Current configuration:
Vendor ID: 0x0bda
Product ID: 0x2838
Manufacturer: Realtek
Product: RTL2838UHIDIR
Serial number: 00000001
Serial number enabled: yes
Bias-T Always ON: yes
Direct Sampling Always ON: no
New configuration:
Vendor ID: 0x0bda
Product ID: 0x2838
Write new configuration to device [y/n]? y
Configuration successfully written.
Please replug the device for changes to take effect.
pi@GaragePi:~ $ ./rtl_biast -b 1
Background: the bias-t is enabled by controlling one of the GPIO (general-purpose I/O) pins on the RTL2832U chip.
AFAIK the 2832 itself wonât set the GPIO pin based on the EEPROM configuration. So that âalways onâ setting is a purely host-side function, it relies on the host reading the EEPROM state and then setting the GPIO appropriately.
This requires a librtlsdr which is aware of the bias-t and the special EEPROM setting, and itâs quite likely that some of the software youâre running is not aware of this.
(Also - speaking as the past author of dump1090-mutability - donât use it, itâs ancient; use dump1090-fa or readsb)
