You go through the tutorials, but your bias tee isn’t working quite right… you’re getting nothing on your 1090 feed… even with running the command line stop1090/enable bias tee/start1090
Your solution is to tell your software which device you have listed in your rtl_test that you need to enable the bias tee software. You can do this by an additional argument in this bias-t.conf. the “-d” argument identifies which device in the rtl_test list you need to enable your software bias tee in your v3 radio.
Understand that I do have the serial #s already set for my 1090/978 radios. I didn’t try if a -s 00001090 would work… that might be cleaner… -d is the arg for device, not serial and this information is going into the bias-t config. I’m slightly afraid to try it because I spent almost two hours deciphering what was happening.
I’m actually running the non-bias tee version at this very moment on my 978 radio. It’s an experiment; I’ve been having some poor 978 performance.
Of note: I had considered that I had light GA traffic. Then another user had posted on this forum that they was seeing 100+aircraft on 978 traffic per day. I’m about 60 miles from that user… so me seeing 1-5 per day wasn’t making sense.
I’m running the FA antennas, I have both blue and orange FA radios, the nooelec dongle, and just put in the rtlsdr v3 + 1090bias tee to attempt to improve performance… I’m still learning all the software and such along with experimenting with the best possible performance setup; I live in an area where I am not allowed exterior antennas per the HOA; antennas are in the peak of my townhome attic, which is ~~ 40’ up from ground level.
A few modifications from this, as I have different radios in place. This is in a closet on the 3rd floor; our first 90 degree day had my pi up to almost 70’C so I changed the setup. I did start in the attic though
So now the antennas and the bias-tee that chrisjohnston50 linked up top are in the attic. The green(black) 1090FA antenna ----> FA light blue filter ------->ADS-B LNA ------ > Times Microwave 99-6MMB-ON0F —[project box]—> rtl-sdr v3 ----->usb extension 1’ ------> usb hub ------>Pi
I ditched the anker power supply for a ‘Plugable USB 2.0 Powered Hub’ ; it was on a site that found it compatible to power both the Pi and accessories. I did get some performance improvement going this route. I added in ferrites and shorter USB extension cables, as the FA radios cannot sit side-by-side.
I lost my powerline adapter to a nearby lightning strike/power surge (you can see the adapter sideways in the picture) along with three ports in the router I had nearby. I had been struggling with wifi performance so I invested in a Netgear Orbi and have my ethernet lines and improved wifi performance on this level of the house.
The blue plastics are 3d printed and I pulled a CAD for my project box. In the top of the box is a case fan to ensure everything stays cool inside.
I plan on running the script for setting gains.
I’m not too far away from getting an o-scope and doing more optimizing…
I’m becoming a bit of a junkie with it… before my power surge… my numbers were top 100 … dropped a bit when my site was down.
