(1) This seems to be a low-priced solution.
The down side is very long delivery, Over 2 months.
(2) This is another option, but at 5 times the price of (1).
https://www.ebay.com/itm/Bias-Tee-Operates-from-10MHz-7000MHz-Bias-tee-Bias-T-DC-HDR-12V-or-USB-pwr/282542069310
(3) Another option
https://www.ebay.com/itm/PCT-Series-PCTMPI1G-Power-Inserter-for-PCT-CM-Distribution-Amplifiers-or-Preamp/291540280382?hash=item43e127a43e:g:8HkAAMXQbcRQ5w3O
(4) This is a DIY Bias-T, if anyone is interested in DIY.
Uses a recycled TV Splitter, a 200pF ceramic capacitor, and an axial inductor or self-made coil.
Click on the images in this post to see larger / full size
If you dont have an inductor, dont worry. You can make a DIY inductor by using a wire from an scarp piece of telephone cable or network cable. Larger the dia of coil, and larger the number of turns in the coil, better the performance. Practically more than 7 turns cannot be squeezed in a splitter box, and coil INNER diameter of about 1/4 inch or 6 mm will be ok (Inner dia = the dia of bolt or drill bit on which you will wind the coil), but it is not critical, you may use somewhat larger or smal…
