Please need help again
Hello All,
I had to install PiAware and fr24 again. it took some time, Flightradar s running at least, but Piaware unfortunately stays red instead of green. Running PiAwware status gives me an error. Can someone help me to solve thois?
pi@raspberrypi : ~ $ sudo piaware-status
PiAware master process (piaware) is running with pid 493.
PiAware ADS-B client (faup1090) is running with pid 1252.
Local ADS-B receiver (dump1090-fa) is running with pid 1189.
dump1090-fa (pid 1189) is listening for ES connections on port 30005.
Thanks a lot
Have you set the feeder “Unique Identifier” on the new installation to be the same as the station you had been running?
Most likely you needs this (as humpfrey said):
For Beginners - How to Get Back Existing Station Number in A Fresh Install
In case you have any trouble with fr24 settings, i’ve described them here: Installing dump1090 fa · wiedehopf/adsb-wiki Wiki · GitHub
(this will also fix fr24 settings if they are a problem, which doesn’t seem to be the problem in your case: Bundle install for dump1090fa · wiedehopf/adsb-scripts Wiki · GitHub)
Did you set the location properly?
The location will remain correct if the same station number is used as per wiedehopf’s .first link above.
Thanks for all the replies.
Wiederhopf solution link did it. For some reasons I needed several times to correct the problem. But today I was able to solve it. Do thanks again.
