Piaware ads-b cliente (faup1090) is not running
Hello everyone, I have this problem with my feeder, it tells me that 03 days is offline, but I enter locally the * Noip: 8080 * and if I see traffic, I put the command ‘sudo piaware-status’. I request your support please
root@orangepizero:~# piaware-status
PiAware master process (piaware) is running with pid 1259.
PiAware ADS-B client (faup1090) is not running.
PiAware ADS-B UAT client (faup978) is not running.
dump1090-fa (pid 743) is listening for connections on port 30005.
no program appears to be listening for connections on port 30978.
faup978 is NOT connected to the ADS-B UAT receiver.
got ‘couldn’t open socket: connection refused’
Your feeder ID is xxxxx-xxxx-xxxx-xxxx-xxxx (configured at /etc/piaware.conf:10)
Please show the output of:
pgrep -fa dump1090-fa
Try to restart the unit:
sudo reboot
After that show the output of:
journalctl -eu piaware | grep -v 'reported location\|--lat\|feeder ID'
Thanks for your answer, but I gave you the solution with “#sudo apt-get remove --purge piaware” then restart, and reinstalled "# wget http://flightaware.com/adsb/piaware/files/packages/pool/piaware/ p / piaware-support / piaware-repository_3.7.1_all.deb “, then proceeded to place the unique id” #sudo piaware-config feeder-id ", restart and is online again, thank you very much.
