Dump1090 is not running
cdPiAware master process (piaware) is running with pid 1004.
PiAware ADS-B client (faup1090) is not running.
Local ADS-B receiver (dump1090) is not running.
no program appears to be listening for ES connections on port 30005.
got ‘couldn’t open socket: connection refused’
I’m trying to set up a new feeder. all is well… except…
check the output of
and/or
sudo journalctl -xe|grep dump1090-fa
did you follow the instructions and install dump1090-fa properly without errors at the end?
Loaded: loaded (/lib/systemd/system/dump1090-fa.service; enabled; vendor pre>
Active: activating (auto-restart) (Result: exit-code) since Thu 2022-11-03 0>
Process: 703 ExecStart=/usr/share/dump1090-fa/start-dump1090-fa --write-json >
Main PID: 703 (code=exited, status=1/FAILURE)
CPU: 109ms
and this from that second output:
Nov 03 08:37:44 raspberrypizero systemd[1]: dump1090-fa.service: Scheduled restart job, restart counter is at 22.
░░ Automatic restarting of the unit dump1090-fa.service has been scheduled, as the result for
░░ Subject: A stop job for unit dump1090-fa.service has finished
░░ A stop job for unit dump1090-fa.service has finished.
░░ Subject: A start job for unit dump1090-fa.service has finished successfully
░░ A start job for unit dump1090-fa.service has finished successfully.
Nov 03 08:37:44 raspberrypizero dump1090-fa[797]: Thu Nov 3 08:37:44 2022 CDT dump1090-fa 7.2 starting up.
Nov 03 08:37:44 raspberrypizero dump1090-fa[797]: rtlsdr: no supported devices found.
Nov 03 08:37:44 raspberrypizero systemd[1]: dump1090-fa.service: Main process exited, code=exited, status=1/FAILURE
░░ An ExecStart= process belonging to unit dump1090-fa.service has exited.
Nov 03 08:37:44 raspberrypizero systemd[1]: dump1090-fa.service: Failed with result ‘exit-code’.
░░ The unit dump1090-fa.service has entered the ‘failed’ state with result ‘exit-code’.
I didn’t seem to get any errors when installing Dump1090. I see the comment about rtlsdr: no supported devices found. My dongle is the same Nooelec dongle I have used previously (it’s warm so i know it’s plugged in). Is there a command to see the status of the sdr dongle directly?
You could try rtl_test -t command see if that shows anything up.
Thanks! I got “no supported devices”. So out of curiosity, I swapped USB’s, rebooted and it’s working now. I guess always check connections.
I had this as well some months ago. Sometimes it helps to squeeze the connect a little bit that it is more tight in the jack.
Or the jack is broken
