pi@Raspberrypi3ADSB:~ $ piaware-status
PiAware master process (piaware) is running with pid 683.
PiAware ADS-B client (faup1090) is running with pid 937.
PiAware mlat client (fa-mlat-client) is running with pid 8900.
Local ADS-B receiver (dump1090-fa) is running with pid 479.
dump1090-fa (pid 479) is listening for ES connections on port 30005.
Thanks - you had me second guessing that I was looking at the wrong Pi. “Raspberrypi3ADSB” is my Pi with both 1090 and 978 receivers. I think I found the difference though. Sudo. When I use sudo, it reports normally. Otherwise, it says it’s NOT running.
pi@Raspberrypi3ADSB:~ $ sudo piaware-status
PiAware ADS-B UAT client (faup978) is running with pid 2708.
Local ADS-B UAT receiver (dump978-fa) is running with pid 2648.
dump978-fa (pid 2648) is listening for UAT connections on port 30978.
faup978 is connected to the ADS-B UAT receiver.
dump978 is producing data on localhost:30978.
Ah, silly me. Yes, “piaware-config” results in permission denied:
pi@Raspberrypi3ADSB:~ $ piaware-config
warning: /etc/piaware.conf: failed to read config file: couldn't open "/etc/piaware.conf": permission denied
pi@Raspberrypi3ADSB:~ $ sudo piaware-config
allow-auto-updates yes # value set at /etc/piaware.conf:7
allow-manual-updates yes # value set at /etc/piaware.conf:8
receiver-type rtlsdr # value set at /etc/piaware.conf:12
rtlsdr-device-index 00001090 # value set at /etc/piaware.conf:10
uat-receiver-type sdr # value set at /etc/piaware.conf:9
uat-sdr-device driver=rtlsdr,serial=00000978 # value set at /etc/piaware.conf:11
I also learned that if you have a standard package install (not doing anything really custom), but with 1090 and 978. Running piaware-status vs sudo piaware-status will result in a different output. It was messing with my head for quite a bit…
The original reason for having /etc/piaware.conf not world readable was that it could contain sensitive info (username/password). Since we’ve moved away from that now, making it world-readable is probably the simple fix here.
