Newbie / dumb questions
Hello all
I’m new to this and don’t have any background. A few things:
I initially set up my Pi two weeks ago through enabling the PiAware (Debian Package Add-on) 3.5.3. This was a mistake I think as I didn’t have Dump 1090 installed so it didn’t seem to work. I have since burnt a new SD card and got it up and running and I ‘seem’ to be tracking aircraft.
After doing the above last night I read this morning on this forum that I needed to add some script to the config file to identify the new SD card (or some such thing). So I cut and paste the script into the config file and rebooted the Pi. I now have four feeders coming up in my stats page!
Under 30 day ranking:
One feed (15840) shows “Live” and “New” which I presume is the feed that I configured by adding the script to recognise the new SD card.
Just below the above is feed is 15841 which I am guessing is the feed prior to me configuring the SD card to be recognised.
Under Nearby sites:
One feed is marked 'viewing and was last seen 14 days ago. I am guessing this is my first attempt to set up Pi Aware and which I no longer wish to use.
A little further down the list is another feed which shows I joined yesterday and was last seen 7 minutes ago.
All of the above is a little confusing. How do I clean it up so it shows only my current feed?
The Live Feed
I presume this showing what aircraft I am tracking. I know this sounds obvious but I’m just checking. Also, after working nicely and showing overhead aircraft the page has suddenly gone to Error 404 - Not found. Have I broken the internet or does it go down occasionally?
Any assistance welcome. Thank you.
Phil
You can get the status from the command line with the following command
piaware-status
If you have piaware running you can usually get the status webpage by going to
http://IP_of_raspberrypi
You can get to the local map by going to
http://IP_of_raspberrrypi:8080
or
http://IP_of_raspberrypi/dump1090-fa
If you deleted PiAware and reinstalled it you need to reclaim the site to add it to your account.
PiAware - Claim and Link a Brand New PiAware Ground Station - FlightAware
