I just updated to the latest versions of everything and when I connect to the RasPi and access the local host page, it doesnt seem to work. I get the FlightAware frames across the top and the columns for flight tracking on the right, but the map doesn’t show and i dont see any of the data from the flights being seen. The stats page is recording so it seems that the antenna is working, just not displaying any data.
External IP definitely changed - move the raspi to a different place on a different network. I tried reinstalling PiAware and Dump1090 but still can’t see any returns on the map - The map itself doesn’t even show up and things like the Settings link don’t work.
I have same problem. Error message about Ajax call log shows no ADS-B data program seen listening on port 30005 for 30 seconds, next check in 60s feed to flight aware is ok
Looks like I may have a conflict between flight aware and flight24 problem started after loading flight24
There is a setting in the ini file to run single or multiple flight programs
This ini file is accessed from the pi computer directly. I have never accessed the pi comp.
Could I delete flight 24, re load flight aware on SD card???
How did you install FR24?
FR24 installation requires to SSH to Pi, then copy-paste installation script in the ssh terminal. Open the same SSH terminal, and copy- paste the commands I have posted.
If you changed location and network, the Raspberry might have got a new local IP address.
Check your router what it is, then you can access it on this one.
Ok, when I reloaded the image in SD card I should have been setup to run flight aware and not fr24
I deleted fr24 before reflashing ad card
After reflash I still had same Ajax error
Got to looking and power would drop low on pi board when radio was on
Dug around and found a sure nuff heavy duty power supply
Work great for now. I hope to edgamacate myself on using pi for some automation project
Any sources would be appreciated my last programing do-da was Fortran and cognos
