Hi, I wanted to find out if I can run plane plotter on raspberry pi or some other type of lower power computer? I have an microADS-B IP receiver v.4 option3 ADS–B receiver made by microadsb.comthat I would like to feed 24 hours a day I would also like to view plane plotter program on my desktop computer any help any help would be appreciated
You could probably to it with github.com/flightaware/beast-splitter and an RPI.
Or even just feeding it directly into an RPI running dump1090.
Hi, Thanks for the help what about using plane plotter? and on the raspberry pi I would need to 2 rj45 ethernet as the microADS-B IP receiver uses POE ethernet for communications to plane plotter
You might take a look at David Taylor’s work at
satsignal.eu/raspberry-pi/dump1090.html
Planeplotter from the Rpi runs ppup1090. In needs a credential file from planeplotter I think coaa.h to compile it.
Check with
www.coaa.co.uk/planeplotter.htm
If you decide on a single board pc, there is a very easy way to get feeding a number of services very quickly and reliably.
https://github.com/jprochazka/adsb-receiver
There is a very lengthy thread with support from developer and other users here
ads-b-flight-tracking-f21/ads-b-receiver-project-setup-scripts-t36532.html
Hi thanks for the help I also found this amazon.com/dp/B018FVOHCW/re … vxbXBH1JHN
Also I am not using DVB-T dongle I have IP based ADS-B receiver
