Greetings. I am new to ADSB feeding. Currently I am feeding to FR24, using a USB Mode-S Beast.
Without any knowledge on how-to, would be appreciate if anyone could provide me step by step setup instructions in order to feed to FlightAware as well.
Update your apt package sources and install PiAware. This will install all the required dependencies on your Raspberry Pi.
sudo apt-get update
sudo apt-get install piaware
Enable automatic and manual (web-based, via your request) PiAware software updates. These updates are disabled by default. To leave updates disabled, skip this step.
(2) INSTALL BEAST-SPLITTER
sudo apt install beast-splitter
(3) CONFIGURE BEAST-SPLITTER
sudo nano /etc/default/beast-splitter
In above file, changed
ENABLED=βnoβ
to
ENABLED=βyesβ
Saved file (Ctrl+O) Closed (Ctrl+X)
sudo reboot
pi@raspberrypi:~ $ journalctl -u beast-splitter -n 20
-- Journal begins at Fri 2022-02-04 05:04:04 EST, ends at Sat 2022-02-19 21:29:23 EST. --
Feb 19 21:28:34 raspberrypi beast-splitter[562]: 0.0.0.0:30005: accepted a connection from 127.0.0.1:50660 with settings R
Feb 19 21:28:34 raspberrypi beast-splitter[562]: 127.0.0.1:50660: connection closed
Feb 19 21:28:35 raspberrypi beast-splitter[562]: 0.0.0.0:30005: accepted a connection from 127.0.0.1:50662 with settings R
Feb 19 21:28:43 raspberrypi beast-splitter[562]: [::]:30005: accepted a connection from [::1]:33096 with settings R
Feb 19 21:28:44 raspberrypi beast-splitter[562]: 0.0.0.0:30005: accepted a connection from 10.0.0.22:33840 with settings R
Feb 19 21:28:58 raspberrypi beast-splitter[562]: 0.0.0.0:30005: accepted a connection from 127.0.0.1:50666 with settings R
Feb 19 21:29:01 raspberrypi beast-splitter[562]: [::]:30005: accepted a connection from [::1]:33118 with settings R
Feb 19 21:29:01 raspberrypi beast-splitter[562]: [::1]:33118: settings changed to RCdfj
Feb 19 21:29:01 raspberrypi beast-splitter[562]: [::]:30005: accepted a connection from [::1]:33120 with settings R
Feb 19 21:29:01 raspberrypi beast-splitter[562]: [::1]:33120: settings changed to RCdfjV
Feb 19 21:29:01 raspberrypi beast-splitter[562]: 0.0.0.0:30005: accepted a connection from 127.0.0.1:50692 with settings R
Feb 19 21:29:01 raspberrypi beast-splitter[562]: 127.0.0.1:50692: settings changed to RCdfJV
Feb 19 21:29:08 raspberrypi beast-splitter[562]: 127.0.0.1:50666: connection closed
Feb 19 21:29:08 raspberrypi beast-splitter[562]: 0.0.0.0:30005: accepted a connection from 127.0.0.1:50700 with settings R
Feb 19 21:29:16 raspberrypi beast-splitter[562]: 0.0.0.0:30005: accepted a connection from 127.0.0.1:50710 with settings R
Feb 19 21:29:16 raspberrypi beast-splitter[562]: 127.0.0.1:50710: connection closed
Feb 19 21:29:18 raspberrypi beast-splitter[562]: 127.0.0.1:50700: connection closed
Feb 19 21:29:18 raspberrypi beast-splitter[562]: 0.0.0.0:30005: accepted a connection from 127.0.0.1:50718 with settings R
Feb 19 21:29:19 raspberrypi beast-splitter[562]: 0.0.0.0:30005: accepted a connection from 127.0.0.1:50724 with settings R
Feb 19 21:29:19 raspberrypi beast-splitter[562]: 127.0.0.1:50724: settings changed to RCdfj
