FA image or Raspian and Repository
I need to reimage soon and am wondering what are the pros and cons of using the PiAware image as opposed to a Raspian image, adding the PiAware repository and installing PiAware.
Initial guess is the FA image is smaller without unnecessary Linux programs installed.
Geffers
Don’t think so, i believe the FA image is based on Raspbian Lite, which avoids the graphical interface and is just a basic system.
The advantage right now of going Raspbian Lite is that you’ll be on the new version.
Raspberry Pi OS – Raspberry Pi
It depends on your level of skills
For a very basic user the FA image is ok, if you have little experience you can also select any of the Raspian images (also as minimum without GUI) and install FA manually afterwards
I started with the FA image to make sure it works in general.
If i would need to reimage now, i would select a Raspian image and the Feeder client individually.
Out of curiosity, and as a learning opportunity for me, how did you reach that decision?
Unless you plan to do more than simply ā€˜see’ planes and ā€˜feed’ them to FA, there is no cons to using the Piaware image, only pros, including re-imaging and being back in service in a couple of minutes, if it comes to that.
As a matter of fact, I don’t even bother with OS updates. If there is a serious issue, FA will release a new image, hopefully, and it’ll be up and running in a couple of minutes.
If you want more control and ā€˜freedom of movement’, then installing the packages individually is the way to go.
Actually, I now keep a spare SD already configured, so ā€˜returning to service’ is even faster.
I do use Lite for both my PiAware systems, the new ā€˜Buster’ image, will the PiAware update ok with that I wonder? It has only just been released to coincide with the Pi4 I believe.
Geffers
Dxista
2h
Quite a coincidence really, my PiAware Zero runs 24/7 but decided to install the Custom Web Interface for dump1090-fa written by weiderhopf - it worked then disappeared on reboot. Seems corrupted microSD card, not noticed as PiAware runs mainly from memory.
Geffers
which update?
The current version works fine on Buster.
(except dump978-fa)
Yes, but Linux is very useful
@send2gl
I just now wrote Raspbian Buster on microSD card, then installed piaware and dump1090-fa (both by package install) and it works fine.
The dump978-fa’s pre-built package available with Flightaware repository is NOT compatible with Buster. If you want dump978-fa, then you have to build the package from source code as shown in this post:
https://discussions.flightaware.com/t/piaware-sd-card-image-3-7-1-quickstart-guide/48262/345
NOTE:
You can install packages for piaware and dump1090-fa in any one of the following two ways:
(1) Follow instructions on this page:
https://flightaware.com/adsb/piaware/install
OR
(2) Copy-paste following command in PuTTY. It will run all the commands contained in above linked Flightaware page.
sudo bash -c "$(wget -O - https://raw.githubusercontent.com/abcd567a/piaware/master/piaware-on-raspbian.sh)"
The above command takes a while to complete installation. At the end it will ask you to copy-paste your feeder-id from your Flightaware stats page, press Enter Key, then Reboot, and that is all. :slight_smile:
Piaware & Dump1090-fa ver 3.7.1 Package Install on Raspbian Buster
pi@raspberrypi:~ $ cat /etc/os-release | grep PRETTY
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 4.19.57-v7+ #1244 SMP Thu Jul 4 18:45:25 BST 2019 armv7l GNU/Linux
pi@raspberrypi:~ $ sudo systemctl status dump1090-fa
ā— dump1090-fa.service - dump1090 ADS-B receiver (FlightAware customization)
   Active: active (running) since Thu 2019-08-01 19:01:45 BST; 11min ago
 Main PID: 404 (dump1090-fa)
    Tasks: 3 (limit: 2200)
   Memory: 6.8M
           └─404 /usr/bin/dump1090-fa --device-index 0 --gain -10 --ppm 0 --net-bo-port 30005 --max-range 360 --net --net-heartbeat 60 --net-ro-size
Aug 01 19:01:45 raspberrypi systemd[1]: Started dump1090 ADS-B receiver (FlightAware customization).
Aug 01 19:01:45 raspberrypi dump1090-fa[404]: Thu Aug  1 19:01:45 2019 BST  dump1090-fa 3.7.1 starting up.
Aug 01 19:01:45 raspberrypi dump1090-fa[404]: rtlsdr: using device #0: Generic RTL2832U (Realtek, RTL2832UFA, SN 00000101)
Aug 01 19:01:45 raspberrypi dump1090-fa[404]: Detached kernel driver
Aug 01 19:01:45 raspberrypi dump1090-fa[404]: Found Rafael Micro R820T tuner
Aug 01 19:01:46 raspberrypi dump1090-fa[404]: rtlsdr: enabling tuner AGC
Aug 01 19:01:46 raspberrypi dump1090-fa[404]: Allocating 4 zero-copy buffers
pi@raspberrypi:~ $ sudo systemctl status piaware
ā— piaware.service - FlightAware ADS-B uploader
   Active: active (running) since Thu 2019-08-01 19:01:45 BST; 12min ago
 Main PID: 407 (piaware)
    Tasks: 4 (limit: 2200)
   Memory: 18.7M
           ā”œā”€407 /usr/bin/piaware -p /run/piaware/piaware.pid -plainlog -statusfile /run/piaware/status.json
           ā”œā”€535 /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost --net-bo-port 30005 --stdout --lat 43.xxx --lon -79.xxx
           └─560 /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:3010
Aug 01 19:03:53 raspberrypi piaware[407]: mlat-client(560): fa-mlat-client 0.2.10 starting up
Aug 01 19:03:53 raspberrypi piaware[407]: mlat-client(560): Using UDP transport to 70.42.6.197 port 8160
Aug 01 19:03:53 raspberrypi piaware[407]: mlat-client(560): Listening for Beast-format results connection on port 30105
Aug 01 19:03:53 raspberrypi piaware[407]: mlat-client(560): Listening for Extended Basestation-format results connection on port 30106
Aug 01 19:03:53 raspberrypi piaware[407]: mlat-client(560): Input connected to localhost:30005
Aug 01 19:03:53 raspberrypi piaware[407]: mlat-client(560): Input format changed to BEAST, 12MHz clock
Aug 01 19:03:53 raspberrypi piaware[407]: piaware has successfully sent several msgs to FlightAware!
Aug 01 19:03:54 raspberrypi piaware[407]: mlat-client(560): Beast-format results connection with ::1:30104: connection established
Aug 01 19:07:20 raspberrypi piaware[407]: 1201 msgs recv'd from dump1090-fa (1117 in last 5m); 751 msgs sent to FlightAware
Aug 01 19:12:20 raspberrypi piaware[407]: 2314 msgs recv'd from dump1090-fa (1113 in last 5m); 1864 msgs sent to FlightAware
Wasn’t sure about Buster.
Geoff
Tested, found ok
