This is a new one for me - the pi is checking in, but for the last hour or so it hasn’t been sending data. I have a cron job set to reboot it every half hour (edimax wifi problems that did not get resolved by disabling PS…) anyway can a problem on Flightaware cause this? Since is has been reset at least twice since the data feed has dropped off, I tend to think it could be… maybe.
Any commands from the drop down I should try sending?
djmd808:
I’m seeing the same thing as of around 1500UTC:
Data Feed: Today - about 2 hours ago
Feeder Check-in: Live - 2 minutes ago
Thanks for posting. I thought it was something I did because I was changing my configuration.
areyes
August 21, 2015, 4:10pm
3
Same thing here with my two receivers. I restart both but no feed to FA.
Hi djmd808,
We are working on fixing this issue for you.
A case has been assigned on your behalf (Case #52898 ). Someone will reach out to you shortly.
Your patience is appreciated.
Best regards,
Paul
Hi GDoggRaspberry,
A case has been assigned on your behalf (Case #52899 ). Someone will reach out to you shortly.
Best regards,
Paul
Hi areyes,
A case has been assigned on your behalf (Case #52900 ). Someone will reach out to you shortly.
Best regards,
Paul
Looks all cleared up. Thanks Paul!
hsran
August 22, 2015, 7:09am
8
Flightfeeder-1399
Data Feed: Today - about 3 hours ago
Feeder Check-in: Live - about 1 minute ago
Harman,
Seems like an issue with Flightfeeder 6.4. I am (still?) on 6.2 and no such issues though range and message count seems unusually low today
