FlightFeeder data problems
When checking status of my FlightFeeder site, I saw that last Data Feed was 53 minutes ago and Feeder Check-in was 24 minutes ago. Then checked other FlightFeeder sites from worldwide coverage map, all of the sites I have checked randomly from Europe & USA, seems to be same.
Other types of feeding like PiAware and Planeplotter have no problems.
Is there a general problem?
I am facing the same issue:
Data Feed: Today - about an hour ago
Feeder Check-in: Live - 19 minutes ago
Current Streak: 82 days (05-Jun-2015 - Today)
Longest Streak: 94 days (01-Mar-2015 - 02-Jun-2015)
Feeder Type: FlightFeeder 6.4
Multilateration (MLAT): Receiver Not Supported
Same here,
Feeder Check-in: Live - 3 minutes ago
Longest Streak: 419 days (03-Jul-2014 - Today)
Feeder check-in shows where I rebooted FF box 3 minutes ago. Live feed is OK tracking 40+ aircraft
Edit to add, the collection graphs are updating OK
oh me too, today install new system not uploading data
Data Feed: Today - 大约 5 小时 以前
Feeder Check-in: Live - 8 分钟 以前
Longest Streak: 29 days (2015年 07月 28日 - Today)
Nearest Airport: Kunming Changshui Int’l (云南 昆明 CN) (ZPPP / KMG) - People’s Republic of China
Hi emirhan,
We are working on fixing this issue for you.
A case has been assigned on your behalf (Case #53075). Someone will reach out to you shortly.
Your patience is appreciated.
Best regards,
Paul
i thought mine was just dead, so it isn’t really dead?
Data Feed: Today - ongeveer 18 uren geleden
Feeder Check-in: Live - 6 minuten geleden
no data over port 30002 and no aircraft shown on internal page.
edit: on the lower pcb led 1 green and 3 blue are on, 6 red and 7 (green?) flash dimly for a very short time every 2-3 seconds.
after 343 days i loose my streak which started day one :frowning: offline for 24hrs now.
i did a simple test and the core of the inner cable of the coax connecting to the feeder is still connected to the antenna. i got a beep when i connected both ends with my tester.
I am also showing Data problems:
Data Feed: Today - about 3 hours ago
Feeder Check-in: Live - 2 minutes ago
Longest Streak: 1 days (25-Aug-2015 - 25-Aug-2015)
Feeder Type: PiAware (SD Card) 2.1-2
Multilateration (MLAT): Supported / Enabled
Keri
Hi franzke,
A case has been assigned on your behalf (Case #53144). Someone will reach out to you shortly.
Best regards,
Paul
Hi towerdiva,
A case has been assigned on your behalf (Case #53146). Someone will reach out to you shortly.
Best regards,
Paul
The issue with my feeder is back.
Yep, it’s back,
Feeder Check-in: Live - 5 minutes ago
Longest Streak: 420 days (03-Jul-2014 - Today)
Collection graph show data getting to server, but “no data feed” on stats page
We’re working on some server-side problems that are impacting data collection. Not a client issue this time.
You should have a red banner forum announcement when you are having problems with description of symptom.
It is aggravating to run a pile of diagnostics, possibly creating more problems , and then finding that it is something totally out of my control.
Agree with you.
I’m happy with the support i got, my feeder got corrupted so i flashed the sd card as explained in the mail i received. Now it works again.
Thanks again dbaker!
Only transferring my key seems to be a bit difficult… reception is back but not showing on fa site. (note to fa: don’t look at the quality of reception, the antenna is laying horizontally inside next to electronic devices :mrgreen: )
well… i did just shut down my flightfeeder, no need to keep it online.
mail me when you have figured out how to get my data back online.
case 53144
request 62912
Sad to shut down the feeder, hope it gets fixed as soon as possible.
too bad they don’t do enough to support their own software/hardware for a feeder that gives them a lot of data. for one day i was even number one :wink:
https://dl.dropboxusercontent.com/u/90516818/fa1.jpg
after 15 days (…) my flightfeeder came back online. tnx i suppose.
moved the feeder to a better location inside on ground floor causing the increased reception. If i have the time i’ll move it back to the roof tomorrow.
https://dl.dropboxusercontent.com/u/90516818/fa2.png
