My receiver sends an hour ago no data and I do not know why.
Many receivers close to me have probably the same problem. Status Last seen: Today.
What can be wrong?
Been off seven hours for me, shows FlightFeeder box as ‘live’ but no data feed. The box shows five ‘greens’ and the bytes sent is ticking up. I can see live data locally, but it’s obviously not getting to Flightaware.
I see your FF was down from 2am - 8am UTC, but it seems to be back now. The timing suggests it is an unrelated problem as that was several hours after the piaware endpoint problem (plus current FFs use a different endpoint anyway)
Your MAC address should not change unless you have changed hardware, assuming you are using a Raspberry Pi. If you’re not using a Pi, then you will need to diagnose the problem yourself, I can’t provide much help for other systems.
Regardless, I think you need to stop reinstalling and start explaining what you’re doing. If you reinstall every time there is a problem, you destroy any diagnostic information that could help fix the problem.
Raspberry Pi MAC addresses start with b8:27:eb and are found from the Pi’s CPU serial number which does not change.
You should be looking at the MAC address for eth0 even if you are using wireless; the wireless MAC address is not used.
