Hi adsb not sending but see pics all seemed to be working ok my end
is server working ok my other adsb is working
swapped airspy over not that antenna is up on roof
mlat is working over night ok
I have the same issue on some but not on all of my feeders, this seems to be serverside related.
@obj any reason why the ADSB 1090 signals aren’t coming through ? Seems to be a server issue there.
Example sites with issues:
76816
166692
203214
206162
252411
Logs are unavailable for these sites via the server
Same here thanks tom
I had a similar situation occur at around 1400 Hrs PDT (US) that lasted about 3 hours (site 180204). Locally everything looked fine but Stats page showed very low position and aircraft numbers. Even though it seemed to be a FlightAware server problem and not my problem, I rebooted the Rpi and things came back to normal on the Stats page. I know that doesn’t make much sense, but that’s what happened!
Thanks Jim, I solved it by restarting the piaware proces, the dump1090-fa was running fine (sites were reporting as expected to other sites like FR24) so the issue had to be within piaware.
sudo service piaware restart
Sites started reporting normally after that.
similar issues… i restarted piaware service to get it to work again… but this seems to be a flightaware server issue. All other feeder services (adsbexchange and adsbhub are receiving my feeds).
logs also show that flightaware is receiving data.. but the statistics says it’s not.
Hi all,
had the same problem yesterday. Dis not restart my Piaware, so it was a Flightaware problem.
