Looks like the server is having issues.
My data is being sent fine, but it looks like data isnt processed
My graphs and number of planes seen is hardly getting updated with new planes.
I double checked it with other feeders which show the same so its not only me.
Als my map of my feeders shows many planes so im pretty sure its not on my side
Same here also in the UK around the same time.
Piaware running but “my adsb” screen not updated for 2 hours, dump1090 running and i can see local graphic map/aircraft from dump1090 in "my adsb " screen when i click on link .
piaware-status
dump1090 is running.
faup1090 is running.
piaware is running.
dump1090 is listening for connections on port 30005.
faup1090 is listening for connections on port 10001.
faup1090 is connected to port 30005
piaware is connected to port 10001.
piaware is NOT connected to FlightAware.
dump1090 is producing data on port 30005.
dump1090 is producing data on port 10001.
03/08/2015 13:26:39 unrecognized message type 'log' from server, ignoring...
03/08/2015 13:26:39 logged in to FlightAware as user komplize
03/08/2015 13:26:39 unrecognized message type 'login' from server, ignoring...
03/08/2015 13:26:48 reconnecting after 60s...
"from server (can’t read “row(type)”: no such element in array), (can’t read “row(type)”: no such element in array
also
03/08/2015 14:02:08 FlightAware server SSL certificate validated
03/08/2015 14:02:08 encrypted session established with FlightAware
03/08/2015 14:02:08 autoUpdate in adept config is enabled, allowing update
03/08/2015 14:02:08 manualUpdate in adept config is enabled, allowing update
03/08/2015 14:02:08 unrecognized message type ‘log’ from server, ignoring…
03/08/2015 14:02:08 that’s too many, i’m disconnecting and reconnecting…
Same for me in Texas. I am re-booting the RasPI now ‘just for good measure’, but expect the outage is on the FA side.
I’m gonna blame the time change (DST) in the US just because…
UPDATE: After the re-boot the RaspPI is feeding again.
Mine is similar although I’m running dump1090-mutability:
piaware-status
dump1090 is not running.
faup1090 is not running.
piaware is running.
dump1090-mutab is listening for connections on port 30005.
dump1090-mutab is listening for connections on port 10001.
dump1090-mutab is producing data on port 30005.
dump1090-mutab is producing data on port 10001.
I just wanted to make sure it wasn’t dump1090-mutab causing any problems.
I’m having problems here, too. Seems to be on the server side. I wonder if the switch to daylight saving time this morning has something to do with it?
03/08/2015 14:22:03 reconnecting after 60s…
03/08/2015 14:22:52 2720 msgs recv’d from dump1090 (146 in last 5m); 198 msgs sent to FlightAware
03/08/2015 14:23:03 connecting to FlightAware 70.42.6.203/1200
03/08/2015 14:23:03 got ‘couldn’t open socket: connection refused’ to adept server at 70.42.6.203/1200, will try again soon…
03/08/2015 14:24:36 connecting to FlightAware eyes.flightaware.com/1200
03/08/2015 14:24:36 got ‘couldn’t open socket: connection refused’ to adept server at eyes.flightaware.com/1200, will try again soon…
03/08/2015 14:25:45 connecting to FlightAware 70.42.6.203/1200
03/08/2015 14:25:45 got ‘couldn’t open socket: connection refused’ to adept server at 70.42.6.203/1200, will try again soon…
03/08/2015 14:27:18 connecting to FlightAware eyes.flightaware.com/1200
03/08/2015 14:27:18 got ‘couldn’t open socket: connection refused’ to adept server at eyes.flightaware.com/1200, will try again soon…
Looks like they may have sent a “restart” out (not reboot). The feeds that were not sending are now. One that was fine is now silent starting the same time frame the others came back. Checked my processes and they have not restarted since Feb 23.
Hi,
Anyone know what the above fault could be, “flights” menu in “my adsb” page is blank , but aircraft and message data stats increasing now, station showing as live so outage restored but still the flight list prob persists.
