Thanks for the info.
Are there any step by step instructions available to build from source?
Not really step by step, take a look at the git and read through the readme…
Thanks for the info. Will go through it.
When installing ADSB Receiver Project, going through the install part you get options to install multiple feeders. How do I select the feeders? or when I get other screens that allow for selecting options? I am still lacking knowledge in command line operations.
I have ADSB Reciever project installed as my secondary system and it is running good. I want to be able to go back and install other feeders. However I dont know Linux but very little, I dont know how to select each individual feeder to be installed. I get a red curser but I dont know how to select each box.
Please help.
Bring cursor to desired feeder by up/down arrow keys.
Press Spacebar. A star will appear at left of selected feeder.
Repeat above for other feeders if you want to install more than one feeder.
Press Enter key.
abcd567, thanks for the help. As you can see, a old helicopter mechanic can learn linux
I have everything installed on my secondary Pi. all is good so far except my feeders.
As you can see the DUMP1090 Mutability is working but the feeder has errors. What am I doing wrong?
post output of following (remove fr24key value before posting)
cat /etc/fr24feed.ini
receiver=“beast-tcp”
pi@raspberrypi:~ $ fr24key=
pi@raspberrypi:~ $ host=“localhost:30002”
pi@raspberrypi:~ $ bs=“no”
pi@raspberrypi:~ $ raw=“no”
pi@raspberrypi:~ $ logmode=“1”
pi@raspberrypi:~ $ windowmode=“0”
pi@raspberrypi:~ $ logpath=“/var/log/fr24feed”
pi@raspberrypi:~ $ mpx=“no”
pi@raspberrypi:~ $ mlat=“yes”
pi@raspberrypi:~ $ mlat-without-gps="yesreceiver=“beast-tcp”
fr24key=
bs=“no”
raw=“no”
logmode=“1”
windowmode=“0”
mpx=“no”
mlat=“yes”
With receiver=beast-tcp, the correct port number is 30005. You have used 30002, which has caused failure.
You can change port number by any one of the following two methods:
Edit file fr24feed.ini
sudo nano /etc/fr24feed.ini
Change port number to 30005 -
Visit in your browser, the FR24 Settings Page at following address:
ip-of-pi:8754/settings.html
Change port number to 30005.
Click “Save” button, then click “Restart” button. Both these buttons are at bottom-right of settings page.
Part of Settings page at ip-of-pi:8754/settings.html
Its working!
Thank you!
ABCD567,
Thanks to you and your knowledge I have two feeders up and running perfectly.
Yesterday I had reformatted my computer since I had it completely cluttered up. I had gone back and installed the essential programming to include VM Box and Raspberry Jessie. Now I am wanting to install and run a VDL Mode 2 program called DUMPVDL2. Its the newer mode for VDL2 acars.I have MULTIPSK to run this mode but I want to get more experience on Linux and raspberry. Here is his project. GitHub - szpajder/dumpvdl2: VDL Mode 2 message decoder and protocol analyzer
Now With my very limited knowledge in Linux (thanks to you) I did manage to get some things to happen but not work. I am having problems with getting the Install librtlsdr. How would I do this?
Thanks ABCD. I really appreciate it.
Use sudo at start of command.
No sudo
pi@raspberry:~ $ apt-get install librtlsdr-dev
E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
With sudo
pi@raspberry:~ $ sudo apt-get install librtlsdr-dev
Reading package lists... Done
Building dependency tree
The following extra packages will be installed:
librtlsdr0
The following NEW packages will be installed:
librtlsdr-dev librtlsdr0
0 upgraded, 2 newly installed, 0 to remove and 172 not upgraded.
Need to get 57.0 kB of archives.
After this operation, 169 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://ftp.debian.org/debian/ jessie/main librtlsdr0 i386 0.5.3-3 [27.4 kB]
Get:2 http://ftp.debian.org/debian/ jessie/main librtlsdr-dev i386 0.5.3-3 [29.5 kB]
Fetched 57.0 kB in 0s (91.5 kB/s)
Selecting previously unselected package librtlsdr0:i386.
(Reading database ... 108724 files and directories currently installed.)
Preparing to unpack .../librtlsdr0_0.5.3-3_i386.deb ...
Unpacking librtlsdr0:i386 (0.5.3-3) ...
Selecting previously unselected package librtlsdr-dev.
Preparing to unpack .../librtlsdr-dev_0.5.3-3_i386.deb ...
Unpacking librtlsdr-dev (0.5.3-3) ...
Setting up librtlsdr0:i386 (0.5.3-3) ...
Setting up librtlsdr-dev (0.5.3-3) ...
Processing triggers for libc-bin (2.19-18+deb8u10) ...
(1) INSTALL THE SOFTWARE DUMPVDL2
sudo apt-get update
git clone https://github.com/szpajder/dumpvdl2.git
cd dumpvdl2
make
sudo wget -O /etc/udev/rules.d/rtl-sdr.rules "https://raw.githubusercontent.com/osmocom/rtl-sdr/master/rtl-sdr.rules"
sudo reboot
(2) After Reboot, run the program DUMPVDL2
cd dumpvdl2
./dumpvdl2 --rtlsdr 0 --gain 40 --correction 42 --output-file vdl2.log
./dumpvdl2 --rtlsdr 0 --gain 40 --correction 42 136725000 136975000 136875000 --output-file vdl2.log
dumpVDL2 v1.3.1-3-gfc3e2d3
Sampling rate set to 1050000 sps
Found 1 device(s):
0: Realtek, RTL2832UFA, SN: 00000001
Exact sample rate is: 1050000.026077 Hz
Center frequency set to 136850000 Hz
Device #0: gain set to 40.20 dB
Device 0 started
Latest version released few days ago: 2.6.3
In Branch 2.7.0, OpenSky-Network feeder has been added today:
$ sudo apt-get update
$ sudo apt-get install git
$ git clone https://github.com/jprochazka/adsb-receiver.git
$ cd adsb-receiver
$ git reset --hard 28ef0b2
HEAD is now at 28ef0b2 Added OpenSky Network feeder support.
$ ./install.sh
Is there anyway to update to the latest adsb-receiver without it deleting over my markers, dB, confid and scripts file?
Thanks @abcd567 but still doesn’t tell me if its going to overwrite my dB and markers file. I ask as i have had to add heaps of local aircraft to the dB and i have also created lots of aircraft svg’s.
I cannot tell you that because I have never upgraded an existing installation of adsb-receiver.
When I need to upgrade, I format my micrSD card, then upgrade the entire system as follows:
Download and write latest OS image, then install latest versions of all software, including adsb receiver.
