The other way round. The Pi struggles to find the Router.
Do you by chance used mixed WiFi 2.4GHz/5GHz using the same SSID?
Sometimes this is causing problems. Also special characters in the SSID password can be a reason.
Setting up a static IP wont help. You can simply configure the router that it always assign the same IP to the Pi which ends up in the same result.
Yes I have a Dual band router but with separate SSID
There is a comma mark in my password yes but not in the SSID
I am also running another Rpi with Weather Station software that always links straight back to the Wi-Fi if the router is rebooted instantly no issues !
I think I may have found the issue but haven’t had time to address it yet , I currently have the Rpi 4 on ethernet using a wireless Wi-Fi extender as was the only way i could get it connected again.
I found the MAC address is one digit out on wireless than on ethernet ie b4 and b5 at the end of the address.
I think i need to alter the Rpi wireless MAC address to the correct one when trying to connect to the static IP address on Wi-Fi
Any Thoughts if that sounds a valid reason for the issue ?
I’m still having a problem but found out I had my Router set in the wrong mode, I’ve got that fixed but now I cant set a static IP address. I use my broadband supplied Router with its Wi-Fi disabled then I run my own Wi-Fi Router in access point mode via ethernet.
What Baffles me is if I reboot my router piaware always ends up on a new IP address which is frustrating as then need to find it and reset all my bookmarks, Putty and VRS to the new IP address
Yet my other Rpi running a weather software program doesn’t !! It always on same IP address
Can I put a line in the config file ie Force-IPaddress 192.168.0.** ?
I think my Netgear is disabled for DCHP as I have no access to reserve IP address in any setting.
See the screen shot as I’m lost with this. I have reserved the piaware ip address on my other router which does have DCHP enabled but is my Netgear saying on because of that fact? I’ve been through every setting on the Netgear and there is no option to disable DCHP or add static or reserve IP address.
