Hi I wanted to get adsb on my sdr thats on a Ubuntu computer I tried installing dump1090 from ([OUTDATED] Howto Install Piaware 3.8.1 on Ubuntu-20 AMD64 & Kali-2020 AMD64 on PC) now my sdr says This receiver is currently unavailable due to technical issues.
Error Message:
No SDR Devices available
But it was working before. What do I do ?
(1) Please post output of following command:
apt-cache policy dump1090-fa
(2) Please post output of following command
lsb_release -a
(3) Please issue following commands, and post output of last command
sudo apt install rtl-sdr
sudo systemctl stop dump1090-fa piaware
rtl_test -t
Command 1 i get
dump1090-fa:
Installed: 9.0~bpo11+1
Candidate: 9.0~bpo11+1
Version table:
*** 9.0~bpo11+1 100
100 /var/lib/dpkg/status
Command 2 i get
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 22.04.3 LTS
Release: 22.04
Codename: jammy
3rd command i got
sdr@SDR:~$ sudo apt install rtl-sdr
rtl_test -t
[sudo] password for sdr:
Reading package lists… Done
Building dependency tree… Done
The following NEW packages will be installed:
rtl-sdr
0 upgraded, 1 newly installed, 0 to remove and 52 not upgraded.
Need to get 58,3 kB of archives.
After this operation, 236 kB of additional disk space will be used.
Get:1 http://cz.archive.ubuntu.com/ubuntu jammy/universe amd64 rtl-sdr amd64 0.6.0-4 [58,3 kB]
Fetched 58,3 kB in 1s (74,9 kB/s)
Selecting previously unselected package rtl-sdr.
(Reading database … 216729 files and directories currently installed.)
Preparing to unpack …/rtl-sdr_0.6.0-4_amd64.deb …
Unpacking rtl-sdr (0.6.0-4) …
Setting up rtl-sdr (0.6.0-4) …
Processing triggers for man-db (2.10.2-1) …
Failed to stop piaware.service: Unit piaware.service not loaded.
No supported devices found.
rtl_test -t
Hope this all helps
Thank you
forgot to add
tl_test -t
rtl-sdr is already the newest version (0.6.0-4).
0 upgraded, 0 newly installed, 0 to remove and 52 not upgraded.
@davidm7cay
When I issue command rtl_test -t , I get what is shown in screenshot below.
What do you get when you issue command rtl_test -t ?
Won’t get far with that. The sdr is toast/not connected/wrong type.
