Dump1090-fa-minimal
Hi Does anyone know if and what i use from this website below to install dump1090-fa-minimal on a Ubuntu system so i can use ADSB with OpenWeb Rx Plus
GitHub - flightaware/dump1090: Dump1090 is a simple Mode S decoder for RTLSDR devices
Thank you in advance
Install latest version of dump1090-fa minimal on Ubuntu.
It is built with
(1) Support for rtlsdr (DVB-T and other RTL based Dongles)
(2) Support for network mode.
NO support for bladerf, hackrf, limesdr, and soapysdr.
Copy-paste following command in Terminal / PuTTy:
sudo bash -c "$(wget -O - https://github.com/abcd567a/piaware-ubuntu-debian-amd64/raw/master/install-dump1090-fa-rtlsdr-only.sh)"
Click on Screenshot to See Larger Size
Hi I tried it but I get errors
E: Failed to fetch http://flightaware.com/adsb/piaware/files/packages/dists/bullseye/InRelease 403 Forbidden [IP: 104.18.39.201 80]
E: The repository ‘http://flightaware.com/adsb/piaware/files/packages bullseye InRelease’ is no longer signed.
N: Updating from such a repository can’t be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
[ERROR] Error in line 8 when executing: apt update
The bash script I have given in my above post to install dump1090-fa minimal on Ubuntu requires to go to:
https://github.com/flightaware/dump1090
It does NOT require to go to:
http://flightaware.com/adsb/piaware/files/packages/dists/bullseye .
Apparently instead of trying on Ubuntu, you have tried my bash script on Debian Bullseye on which you have already installed piaware from Flightaware repository. When the bash script is run, it first tries to update. As the Flightaware repository signature is broken currently, the bash script gives Error message, and exits. Please try again tomorrow, Hopefully Flightaware will fix their Repository signature by then.
Flightaware repository bug “unsigned” is now fixed by Flightaware.
You can now run the bash script. It wont give error now.
Hi thank you for letting me know it was fixed, i installed the code and it did it well with no faults except it still had not fixed my problem with ADSB in OpenWeb Rx+ as to i still cant see ADSB listed in open web and the feature page still says no next to ADSB. what am i doing wrong??? Thank you
I have no idea about OpenWeb RX, never tried it. Sorry, I cannot help you in this regard.
goodnight! I took advantage of the help to try to solve the same problem on my piaware, but it is still giving the error as below:
error: 3627 bytes of body are still expected
fetch-pack: unexpected disconnect while reading sid
acket
fatal: early EOF
fatal: fetch-pack: invalid index-pack output
ERROR] Error in line 103 when executing: git clone ht
pi@raspberrypi:~ $
@davidm7cay
@AlmirCosta
If you want absolute minimal dump1090-fa, (i.e binary only), then use following commands:
git clone https://github.com/flightaware/dump1090
cd dump1090
make DUMP1090_VERSION=$(git describe --tags | sed 's/-.*//')
sudo install -Dm755 dump1090 /usr/bin/dump1090
(1) The make command will build dump1090 binary with following options.
Building with:
  Version string:   v9.0
  Architecture:     aarch64
  DSP mix:          aarch64
  RTLSDR support:   yes
  BladeRF support:  no
  HackRF support:   no
  LimeSDR support:  no
  SoapySDR support: no
NOTE: The Architecture aarch64 shown above is that of my Pi model 4 with 64-bit Bookworm. In your case it may be different depending on your Pi and OS.
(2) The install command will install the binary in following location:
/usr/bin/dump1090
(3) There will be no skyaware map, and no systemd service file and no startup file. You can run it simply by following commands:
dump1090
OR
dump1090 --interactive
pi@raspberrypi:~ $ dump1090
pi@raspberrypi:~ $ dump1090 --interactive
good morning! thank you for the informations.
