Having an issue with version 2.4.4 (No aircraft icons on map) I tried V3 beta and all working fine except the webadmin plugin doesn’t work. Says does not work with versions past 2.4.9999
I have version 3.0.0 working from a cloud server. Did initial set up by copying the .local/share/VRS/Configuration.xml file to my cloud version and it seemed to work, or so I thought.
Thanks for prompt reply, they appear to be ‘windows’ files. I am running Linux.
Version 2.4.4 would probably work but when installed locally no aircraft icons show on map, stalk and details do but no aircraft. The folder is in the correct place but cannot see any setting for this in the configuration.
Mine actually says will not work on versions later than 2.4.9999 - annoyingly makes configuration changes difficult (or maybe impossible) on a remote installation.
Well, now I can’t get webadmin to work with v2.4.4 either.
Edit: It works. I just had to pause my VPN.
Second edit: OK, getting confused accessing the two VRS instances. I CAN’T get to webadmin in v2.4.4, but I CAN with v3 when I pause my VPN connection.
Getting it running including Web Admin on Linux is quite easy.
Install Mono (which you should have already) and copy the files from the archives to a destination folder.
Then launch vrs without gui and the special command to create a web admin followed the instructions on the site:
change user and pass according to your needs.
If you need to change it afterwards, you will need to remove the local config folder which is stored in the user profile who was running the command.
