Hello everyone,
I’ve just updated to the Skyview map and it is not displaying any altitude or speed data. I have done as I have read on many other discussion posts and already cleared the cache many times, and have ctrl+f5-ed the crap out of it. Does anyone else have any other ideas?
Cheers!
This problem occured because you are using dump1090-mutability ver 1.15~dev, with GUI of dump1090-fa ver 3.6.3.
The solution is to use GUI of dump1090-fa ver 3.5.3 - Click Here to see details
Or just use dump1090-fa in the current version.
If you are using the gui of dump1090-fa i don’t quite see the reason for using the old dump1090-mutability?
If you were using the mutability gui i could understand using dump1090-fa 3.5.3 but the other way around i really can’t sea reason.
So, I have the same issue except I used GitHub - gvanem/Dump1090: A simple ADS-B (Automatic Dependent Surveillance - Broadcast) receiver, decoder and web-server. Needs a RTLSDR USB-stick and/or SDRplay device. for Windows that came with a FlightAware folder prebuilt. Works flawless except I can’t see speed/alt.
Any suggestions for someone running a Windows build on how to fix this? I much prefer the FlightAware dashboard over Tar1090 but not without those two key bits of info.
Probably more a question for the dev of that. His last update on the piaware map pull was 2yrs ago. And may need an update.
You can try copying over the new one to the windows folder structure from someone with a working pi copy (or make a virtual pi on virtualbox and get them)
Essentially some html, js files
