After unable auto claim your device, I have completed the manual claim process (flightaware.com/adsb/piaware/claim/manual) including updating with my FA account and password, which I’m 99.999% confident the right password is entered, as on entering the password a second time, the terminal is returning “no changes were made to password” (or words to that effect) - Either I’ve entered it wrong twice or or it is correct.
User/Pwd cleared using those commands Cleared setting for flightaware-user in /boot/piaware-config.txt:7
Cleared setting for flightaware-password in /boot/piaware-config.txt:8
Linked PiAware Receivers (craigramsay84)
Great news! Your account is associated with the following PiAware receivers and you can view your statistics here:
Looks like you have changed your username recently and piaware was still connected using the old username.
I killed off the old connection to force it to reconnect as the changed username which appears to have worked correctly.
However: the log messages that piaware is forwarding indicate that there is no dump1090 running (and attempts to restart it don’t fix that), which is why no data is being fed. (See /var/log/piaware.log)
Check “sudo journalctl -u dump1090-fa” which should tell you why dump1090 is failing to start.
