I’m having trouble with the install instructions. Following the step-by-step on the website when I try to install piaware I get:
piaware : Depends: libboost-regex1.74.0-icu67 but it is not installable
Depends: libc6 (>= 2.29) but 2.28-10+rpt2+rpi1 is to be installed
Depends: libffi7 (>= 3.3~20180313) but it is not installable
Depends: libgcc-s1 (>= 3.5) but it is not installable
Depends: libmpdec3 but it is not installable
Depends: libreadline8 (>= 7.0~beta) but it is not installable
Depends: libstdc++6 (>= 9) but 8.3.0-6+rpi1 is to be installed
E: Unable to correct problems, you have held broken packages.
I did pick the one for my distribution, just concerning that it’s not complete. And thanks for the links, but that just kind of muddied the water a bit. Hopefully I’ll get some other insights.
I’m trying to load the FA software on a Pi-Star hotspot running on a Raspberry Pi Zero. Unfortunately, the Pi-Star software is only available as a complete image, so I have to use it has the base. Here is the other info: (I’m going to assume the absence of lsb modules is likely at the core of my problem?)
pi-star@pi-star(rw):~$ uname -a
Linux pi-star 5.10.63+ #1459 Wed Oct 6 16:40:27 BST 2021 armv6l GNU/Linux
pi-star@pi-star(ro):~$ lsb_release -a
No LSB modules are available.
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 10 (buster)
Release: 10
Codename: buster
pi-star@pi-star(ro):~$ apt-cache policy piaware
piaware:
Installed: (none)
Candidate: 7.2
Version table:
7.2 500
500 http://flightaware.com/adsb/piaware/files/packages bullseye/piaware armhf Packages
7.2~bpo10+1 500
500 http://flightaware.com/adsb/piaware/files/packages buster/piaware armhf Packages
Well, there you go. I thought I installed the other version (which I got by mistake) but apparently I did not!
The installation appears to have worked, now I only need to get it claimed. Still working on that issue. It doesn’t want to connect automatically and the other application (pi-star) takes over the website access on port 80 - so I can’t see the link to claim manually. Trying to find the unique ID.
But thanks for the help - a stupid mistake on my part.
Tried it - returns blank. No ID. The real question is, where does one get a Feeder-ID. Since the web page cannot find my system automatically, I need to link it manually. But where does one get an ID?
I’ve chatted with support - and they don’t know either!! Looking for any other answers before I just give up.
Dont try to claim from Pi’s browser if you have problem.
Instead, try following address from another computer (Desktop/Laptop/Phone) on same local netwrok (LAN/router) as the Pi is. You must login to your flightaware account from the Laptop/Desktop/Phone from which you are going to the claims page.
Curiosity - (a) if I don’t have a Feeder-ID, how does it feed data? and (b) if the system requires manual association, where does one get a Feeder-ID for a new feeder station?
#adaptive-burst no # using default value #adaptive-dynamic-range yes # using default value #adaptive-dynamic-range-target # no value set and no default value #adaptive-max-gain # no value set and no default value #adaptive-min-gain # no value set and no default value #adept-serverhosts “piaware.flightaware.compiaware.flightaware.com {206.253.80.196 206.253.80.197 206.253.80.198 206.253.80.199 206.253.80.200 206.253.80.201} {206.253.84.193 206.253.84.194 206.253.84.195 206.253.84.196 206.253.84.197 206.253.84.198}” # using default value #adept-serverport 1200 # using default value
allow-auto-updates yes # value set at /etc/piaware.conf:7 #allow-ble-setup auto # using default value #allow-dhcp-duid yes # using default value
allow-manual-updates yes # value set at /etc/piaware.conf:8 #allow-mlat yes # using default value #allow-modeac yes # using default value #beast-baudrate # no value set and no default value #enable-firehose no # using default value #feeder-id # no value set and no default value #force-macaddress # no value set and no default value #http-proxy-host # no value set and no default value #http-proxy-password # no value set and no default value #http-proxy-port # no value set and no default value #http-proxy-user # no value set and no default value #image-type # no value set and no default value #manage-config no # using default value #mlat-results yes # using default value #mlat-results-anon yes # using default value #mlat-results-format “beast,connect,localhost:30104 beast,listen,30105 ext_basestation,listen,30106” # using default value #network-config-style buster # using default value #priority # no value set and no default value #radarcape-host # no value set and no default value #receiver-host # no value set and no default value #receiver-port 30005 # using default value #receiver-type rtlsdr # using default value #rfkill no # using default value #rtlsdr-device-index 0 # using default value #rtlsdr-gain max # using default value #rtlsdr-ppm 0 # using default value #slow-cpu auto # using default value #uat-receiver-host # no value set and no default value #uat-receiver-port 30978 # using default value #uat-receiver-type none # using default value #uat-sdr-device driver=rtlsdr # using default value #uat-sdr-gain max # using default value #uat-sdr-ppm 0 # using default value #use-gpsd yes # using default value #wired-address # no value set and no default value #wired-broadcast # no value set and no default value #wired-gateway # no value set and no default value #wired-nameservers “8.8.8.8 8.8.4.4” # using default value #wired-netmask # no value set and no default value #wired-network yes # using default value #wired-type dhcp # using default value #wireless-address # no value set and no default value #wireless-broadcast # no value set and no default value #wireless-country 00 # using default value #wireless-gateway # no value set and no default value #wireless-nameservers “8.8.8.8 8.8.4.4” # using default value #wireless-netmask # no value set and no default value #wireless-network no # using default value #wireless-password # no value set and no default value #wireless-ssid # no value set and no default value #wireless-type dhcp # using default value
Please post output of following command. It will output piaware log which will help in finding what went wrong.
sudo journalctl -u piaware -e
NOTE:
To properly format and make it easy to read, please type [code] above the first line you copy-paste, and [/code] below the last line of code you copy-paste. Like below
[code]
Output line 1
Output line 2
Output line 3
Output line n
[/code]
