I am trying to install the new Flightaware feeder. After several times I see this after using sudo apt-get install piaware
~To me it looks like the software cannot be installed. I tried to install the 3.8 version.
Any ideas and help is much appreciated. Tried to contact the Flightaware helpdesk, but no succes.
pi@raspberrypi:~ $ sudo apt-get install piaware
Reading package lists… Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
piaware : Depends: libboost-filesystem1.67.0 but it is not installable
Depends: libboost-program-options1.67.0 but it is not installable
Depends: libboost-regex1.67.0 (>= 1.67.0-10) but it is not installable
Depends: libboost-system1.67.0 but it is not installable
Depends: libc6 (>= 2.28) but 2.24-11+deb9u3 is to be installed
Depends: libssl1.1 (>= 1.1.1) but 1.1.0f-3+deb9u2 is to be installed
E: Unable to correct problems, you have held broken packages.
then repeat the stretch install steps. Be sure you do the “update” step.
Alternatively, start afresh with a Raspbian Buster image if you don’t have anything else on the Pi that you need to preserve. Stretch is out of date now.
I started all over. Formatted my sd card on my Mac and formatted it into MS-Dos.
Reinstalled as described.
Now I want to access my Pi, I know I had to created a file ssh as I did in the tgterminal window.
I tried to log in with ssh pi@192.168.xxx.xx used the password as described here"
Enable SSH access
For security reasons, SSH access is disabled by default on new PiAware SD card
installs, starting with version 3.3. To enable SSH, create an empty file on the /boot
partition of the SD card with the filename of “ssh” only (no file extension). When
this file is present, SSH will be automatically enabled. The default login is “pi” and
password “flightaware” to connect via SSH.
But for some reason I see this when I try to use the password:
I formatted my. sd card. into Ms Dos format
Downloaded the piaware-sd-card 3.8.0.img
Flashed it with Balenaetcher
Add a ssh file to the boot on the sd card in the Terminal window on my Mac.
Inserted the sd card into my Pi, could see it was claimed as new feeder ( new sharing key)
I am able to access 192.168.xxx.xx/dump1090
So it feeder is running.
Now I want to access the pi to install the other feeders, used ssh pi@192.168.xxx.xx
After asking for the password I gave flightaware, withe the result access denied
Hope this helps
This is normal when connecting to a new ssh server. It alerts you that it’s a system that’s not recognised yet - in an environment where this is important you would double check the key is correct to make sure you aren’t connecting to the wrong system, so if you get this prompt unexpectedly later you check to see that there hasn’t been some kind of security breach.
Are you using Mac terminal to ssh from? If so, try this:
You need to use the correct IP address for your pi. It might help to allocate a fixed one in your router settings if it’s changing when you power off and on.
Oh you logged in using raspberry as the password? I wasn’t expecting that to work since you said you are using the piaware image - it was just an example in my reply to wiedehopf.
In that case then yes you add other feeders from the command prompt.
