Hi FlightAware Community! I am tryin to upgrade from version 3.6.3 to 3.7.1. When I send the command from the configuration page or when I try and manually upgrade I get the following result(I have two Raspberry Pi 3s running FlightAware…one upgraded no problem and one didn’t):
Reading package lists… Done
Building dependency treea
Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming.
The following information may help to resolve the situation:
** piaware : Depends: libboost-filesystem1.62.0 but it is not installable**
Depends: libboost-program-options1.62.0 but it is not installable
Depends: libboost-regex1.62.0 but it is not installable
Depends: libboost-system1.62.0 but it is not installable
Depends: libreadline7 (>= 7.0~beta) but it is not installable
Depends: libssl1.1 (>= 1.1.0) but it is not installable
Depends: libstdc++6 (>= 5.2) but 4.9.2-10+deb8u2 is to be installed
E: Unable to correct problems, you have held broken packages.
apt-cache search libboost-filesystem
libboost-filesystem-dev - filesystem operations (portable paths, iteration over directories, etc) in C++ (default version)
libboost-filesystem1.49-dev - filesystem operations (portable paths, iteration over directories, etc) in C++
libboost-filesystem1.49.0 - filesystem operations (portable paths, iteration over directories, etc) in C++
libboost-filesystem1.50-dev - filesystem operations (portable paths, iteration over directories, etc) in C++
libboost-filesystem1.50.0 - filesystem operations (portable paths, iteration over directories, etc) in C++
libboost-filesystem1.53-dev - filesystem operations (portable paths, iteration over directories, etc) in C++
libboost-filesystem1.53.0 - filesystem operations (portable paths, iteration over directories, etc) in C++
libboost-filesystem1.54-dev - filesystem operations (portable paths, iteration over directories, etc) in C++
libboost-filesystem1.54.0 - filesystem operations (portable paths, iteration over directories, etc) in C++
libboost-filesystem1.55-dev - filesystem operations (portable paths, iteration over directories, etc) in C++
libboost-filesystem1.55.0 - filesystem operations (portable paths, iteration over directories, etc) in C++Preformatted text
I have tried the following to correct the issue:
sudo apt-get autoclean
sudo apt-get clean
sudo apt-get -f install
The original installation steps:
I have ensured my Pi is up to date:
I also tried the steps in this thread:
Any thoughts our ideas would be appreciated! I hope I am posting this in the right spot. Thanks!
