RaspOS dependencies
Dear all,
i need to set up my ADSB from scratch. So I took a raspberry OS 64bit and flashed it successfully. Started the raspbi, extended the file system and did a full upgrade. When I the try to install dump1090-fa I get an error:
dump1090-fa : Depends: liblimesuite20.10-1 (>= 20.10.0+dfsg) but it is not installable
Depends: libsoapysdr0.7 (>= 0.7.2) but it is not installable
What do I need to do to get that solved?
Thanks a lot,
Marcus
Try installing PiAware first, then dump1090-fa.
Have you done:
apt update
apt dist-upgrade
If that doesn’t solve your issue and you just want to get going, give readsb a try: https://github.com/wiedehopf/adsb-scripts/wiki/Automatic-installation-for-readsb
See also this guide: https://github.com/wiedehopf/adsb-wiki/wiki/Raspbian-Lite:-ADS-B-receiver
You could also take a look at this pre-made image: https://adsb.im
(1) What method/command did you try to install dump1090-fa?
(2) Try following command to fix dependencies issue:
sudo apt --fix-broken install
I used the following commands:
wget https://flightaware.com/adsb/piaware/files/packages/pool/piaware/p/piaware-support/piaware-repository_7.2_all.deb
dpkg -i piaware-repository_7.2_all.deb
apt-get update
apt-get install dump1090-fa rtl-sdr -y
(1) Did you try the following command?
(2) You are using version 7.2 of flightaware repisitory package, while current version of repo is 1.2
Please visit following page to see the current commands which use repo package ver 1.2
https://www.flightaware.com/adsb/piaware/install
Yes I did but didn’t help
Installing piaware first results in:
piaware : Depends: libboost-regex1.74.0-icu67 but it is not installable
Depends: libffi7 (>= 3.3~20180313) but it is not installable
Depends: libmpdec3 but it is not installable
Thanks @abcd567 that works!
