Thermal Heating notification in Flight Feeder
I have observed that after couple of hours of usage, a message stating that the CPU temperature is a bit on the higher side, is shown under anomalies in my FlightAware account. I just wanted to know if it is fine to continue running the flight feeder (as it is apparently meant to run 24x7 and 365 days) or should I switch it off and wait until it cools down. Usually I get warning when the CPU temperature is around 68-70 deg. Centigrade.
It’s OK up to 80C. At around 80C it will start throttling the CPU to try to cool down.
If it doesn’t get much hotter than the ~72C you show there, it’s fine to leave it running.
Do they have RPis inside running them?
I see that you are barely feeding anything:
Maybe he switched it off because of the warning :wink:
Apart from that where did you put your antenna?
@SoNic67
I hope you are viewing my correct feeder stats: NISHANT KUMAR ADS-B Feeder Statistics - FlightAware
@wiedehopf
I have placed the FF antenna on my terrace tied up with an old iron water pipe and I am getting good amount of signal from the aircrafts.! Screenshot_Chrome_20180917-214459|690x388
Sonic was referencing the periods the device was switched off.
The flight feeder should run all the time and never be switched off.
(EDIT: Maybe the internet is just very unreliable in the area?)
Regarding the antenna: If you are in the same position you should be able to see the horizon.
So on the roof for example is a better position.
Greetings to India!
