Really cool the new color of the interface !
And i like to not have again the link of airframes.org.
Thanks for your work
can you explain the fa-flightawarelinks Enable (/disable) FA links in the webinterface
Which way should I have it set … and why … any pros/cons ?
There is no downside to enabling them
ok I find flightawareLinks in defaults.js and script.js but not in config.js
You just add the setting to config.js, that’s what you can do with everything you find in defaults.js
For new installs it’s already present, i’ll add a note for existing users.
Either do it manually or use this command:
echo 'flightawareLinks = true;' | sudo tee -a /usr/local/share/tar1090/html/config.js
Quick question: Where does the flight origin and destination come from?
This flight is documented as HAM - FRA, but the origin is STR. That’s also shown on the FA page:
So, incorrect information from the transponder or wrong decoding?
Just visit the page on your pi, i don’t put http on stuff if it’s just data.
Anyway such data is not transmitted via ADS-B.
On this port my planefinder client is running. Anyways, not mission critical.
As i said that’s where the data is coming from, that webpage you see on that port.
No clue where the data for that client comes from exactly, not my problem
Some day perhaps, probably not though.
Install ModeSMixer2 on RPi. It has a maximum range plot.
You can view the ModeSMixer2’s map with maximum range plot in your browser at following address:
IP-of-Pi:8787
Thanks for ModeSMixe2, i know it, and i have always tested.
But i think it will be better to have this function inside Dump1090-FA, rather than needing to install additional software.
have a look at that…item 8
Yes I saw it, this is the link that I put in my message, but if I add it on my side it will be erased with each update of Dump1090-fa.
I’ll wait for this feature to be added later
You can add it as a separate folder.
sudo nano /etc/lighttpd/conf-enabled/88-al.conf
paste this:
#lighttpd configuration for alkissack interface
alias.url += (
"/al/data/" => "/run/dump1090-fa/",
"/al/" => "/usr/local/share/alkissack/public_html/",
# redirect the slash-less URL
url.redirect += (
"^/al$" => "/al/"
Ctrl-O and enter to save, Ctrl-X to exit
sudo systemctl restart lighttpd
sudo git clone https://github.com/alkissack/Dump1090-OpenLayers3-html.git /usr/local/share/alkissack/
Interface will be available at
http://<address>/al
Thanks that’s perfect !
Layout has changed a bit, let me know if it’s working for you.
Making it user adjustable which columns the table on the right has, is on top of my list.
