dump1090 itself doesn’t maintain a daily count of unique ICAOs or airlines but if you are prepared to monitor at least once every 5 mins you could read data/aircraft.json and maintain your own data from that.
The current format (slightly updated from the last release) looks like this, which should be mostly self-explanatory I hope.
It contains all aircraft that dump1090 knows about at the time of the request. Aircraft are removed after 5 mins of no messages.
{ "now" : 1422010548,
"messages" : 15214,
"aircraft" :
{"hex":"43c1b6","flight":"LOS11 ","messages":2,"seen":7,"rssi":-24.1},
{"hex":"ab15c2","flight":"DAL125 ","altitude":17625,"vert_rate":1600,"track":251,"speed":397,"messages":26,"seen":1,"rssi":-27.5},
{"hex":"400d58","messages":2,"seen":24,"rssi":-26.6},
{"hex":"40058b","squawk":"0562","flight":"BAW73","lat":51.358337,"lon":-0.428238,"seen_pos":13,"altitude":7425,"vert_rate":2688,"track":114,"speed":283,"messages":77,"seen":0,"rssi":-24.4},
// ... lots more
Most fields should be selfexplanatory, except: “now” is seconds-since-Jan-1-1970 when the JSON was generated; “seen” is the number of seconds before “now” when a message was last seen; “seen_pos” is the number of seconds before “now” when the position fields were last updated; “rssi” is received signal strength of recent messages in dBFS.
In the next release there will also be data/stats.json which has all of the reported stats from dump1090 in json form, also with last 1/5/15 min aggregation (and, uh, not very many newlines):
"latest":{"start":1422010896,"end":1422010946,"local":{"blocks_processed":920,"blocks_dropped":0,"modeac":0,"modes":491025,"bad":435318,"unknown_icao":7,"accepted":[53043,2657],"signal":-10.6,"peak_signal":-1.9,"strong_signals":287},"remote":{"modeac":0,"modes":0,"bad":0,"unknown_icao":0,"accepted":[0,0]},"http_requests":3,"cpr":{"global_ok":2804,"global_bad":0,"global_skipped":7,"local_ok":154,"local_skipped":5,"filtered":0},"cpu":{"demod":16231,"reader":3677,"background":245},"messages":55700},
"last1min":{"start":1422010836,"end":1422010896,"local":{"blocks_processed":1099,"blocks_dropped":0,"modeac":0,"modes":587127,"bad":520206,"unknown_icao":6,"accepted":[63754,3161],"signal":-10.7,"peak_signal":-1.9,"strong_signals":696},"remote":{"modeac":0,"modes":0,"bad":0,"unknown_icao":0,"accepted":[0,0]},"http_requests":0,"cpr":{"global_ok":3440,"global_bad":0,"global_skipped":7,"local_ok":154,"local_skipped":10,"filtered":0},"cpu":{"demod":19345,"reader":4382,"background":257},"messages":66915},
"last5min":{"start":1422010596,"end":1422010896,"local":{"blocks_processed":5494,"blocks_dropped":0,"modeac":0,"modes":2925699,"bad":2590985,"unknown_icao":29,"accepted":[319300,15385],"signal":-10.6,"peak_signal":-1.8,"strong_signals":5444},"remote":{"modeac":0,"modes":0,"bad":0,"unknown_icao":0,"accepted":[0,0]},"http_requests":9,"cpr":{"global_ok":17482,"global_bad":0,"global_skipped":22,"local_ok":738,"local_skipped":52,"filtered":0},"cpu":{"demod":96774,"reader":21910,"background":1337},"messages":334685},
"last15min":{"start":1422009996,"end":1422010896,"local":{"blocks_processed":16480,"blocks_dropped":0,"modeac":0,"modes":8924467,"bad":7860030,"unknown_icao":73,"accepted":[1015415,48949],"signal":-10.8,"peak_signal":-1.1,"strong_signals":12962},"remote":{"modeac":0,"modes":0,"bad":0,"unknown_icao":0,"accepted":[0,0]},"http_requests":28,"cpr":{"global_ok":52759,"global_bad":0,"global_skipped":45,"local_ok":2245,"local_skipped":121,"filtered":0},"cpu":{"demod":293390,"reader":65830,"background":4012},"messages":1064364},
"total":{"start":1422009156,"end":1422010946,"local":{"blocks_processed":32769,"blocks_dropped":0,"modeac":0,"modes":18034792,"bad":15913275,"unknown_icao":210,"accepted":[2021489,99818],"signal":-10.8,"peak_signal":-1.1,"strong_signals":32488},"remote":{"modeac":0,"modes":0,"bad":0,"unknown_icao":0,"accepted":[0,0]},"http_requests":49,"cpr":{"global_ok":104227,"global_bad":0,"global_skipped":106,"local_ok":4718,"local_skipped":380,"filtered":0},"cpu":{"demod":587193,"reader":130942,"background":7967},"messages":2121307}
All these files are available from either the internal webserver on port 8080 (e.g. localhost:8080/data/aircraft.json) or as a file in the directory specified by the --write-json command line arg.
