if you buy your seat ahead of time, those seats are all located mid cabin (exit row is always sold out first of course). the people who buy their seats have “priorty boarding” (they board first if they want) then they board the rest of the paxs from back to front like some other carriers.
Thanks for the info, I’ll give them a shot. I would fly out of PSC.
You cannot reserve an emergency exit row seat when you make your reservations. Regardless of the airline, you can only do it at the airport due to the requirements of sitting in that row (see below) and the fact that the airline must determine that you are able to fulfill those requirements.
Part 121.585: Exit seating.
(a)(1) Each certificate holder shall determine, to the extent necessary to perform the applicable functions of paragraph (d) of this section, the suitability of each person it permits to occupy an exit seat, in accordance with this section. For the purpose of this section–
(i) Exit seat means–
(A) Each seat having direct access to an exit; and,
(B) Each seat in a row of seats through which passengers would have to pass to gain access to an exit, from the first seat inboard of the exit to the first aisle inboard of the exit.
(ii) A passenger seat having “direct access” means a seat from which a passenger can proceed directly to the exit without entering an aisle or passing around an obstruction.
(2) Each certificate holder shall make the passenger exit seating determinations required by this paragraph in a non-discriminatory manner consistent with the requirements of this section, by persons designated in the certificate holder’s required operations manual.
(3) Each certificate holder shall designate the exit seats for each passenger seating configuration in its fleet in accordance with the definitions in this paragraph and submit those designations for approval as part of the procedures required to be submitted for approval under paragraphs (n) and (p) of this section.
(b) No certificate holder may seat a person in a seat affected by this section if the certificate holder determines that it is likely that the person would be unable to perform one or more of the applicable functions listed in paragraph (d) of this section because–
(1) The person lacks sufficient mobility, strength, or dexterity in both arms and hands, and both legs:
(i) To reach upward, sideways, and downward to the location of emergency exit and exit-slide operating mechanisms;
(ii) To grasp and push, pull, turn, or otherwise manipulate those mechanisms;
(iii) To push, shove, pull, or otherwise open emergency exits;
(iv) To lift out, hold, deposit on nearby seats, or maneuver over the seatbacks to the next row objects the size and weight of over-wing window exit doors;
(v) To remove obstructions similar in size and weight to over-wing exit doors;
(vi) To reach the emergency exit expeditiously;
(vii) To maintain balance while removing obstructions;
(viii) To exit expeditiously;
(ix) To stabilize an escape slide after deployment; or
(x) To assist others in getting off an escape slide;
(2) The person is less than 15 years of age or lacks the capacity to perform one or more of the applicable functions listed in paragraph (d) of this section without the assistance of an adult companion, parent, or other relative;
(3) The person lacks the ability to read and understand instructions required by this section and related to emergency evacuation provided by the certificate holder in printed or graphic form or the ability to understand oral crew commands.
(4) The person lacks sufficient visual capacity to perform one or more of the applicable functions in paragraph (d) of this section without the assistance of visual aids beyond contact lenses or eyeglasses;
(5) The person lacks sufficient aural capacity to hear and understand instructions shouted by flight attendants, without assistance beyond a hearing aid;
(6) The person lacks the ability adequately to impart information orally to other passengers; or,
(7) The person has:
(i) A condition or responsibilities, such as caring for small children, that might prevent the person from performing one or more of the applicable functions listed in paragraph (d) of this section; or
(ii) A condition that might cause the person harm if he or she performs one or more of the applicable functions listed in paragraph (d) of this section.
(c) Each passenger shall comply with instructions given by a crewmember or other authorized employee of the certificate holder implementing exit seating restrictions established in accordance with this section.
(d) Each certificate holder shall include on passenger information cards, presented in the language in which briefings and oral commands are given by the crew, at each exit seat affected by this section, information that, in the event of an emergency in which a crewmember is not available to assist, a passenger occupying an exit seat may use if called upon to perform the following functions:
(1) Locate the emergency exit;
(2) Recognize the emergency exit opening mechanism;
(3) Comprehend the instructions for operating the emergency exit;
(4) Operate the emergency exit;
(5) Assess whether opening the emergency exit will increase the hazards to which passengers may be exposed;
(6) Follow oral directions and hand signals given by a crewmember;
(7) Stow or secure the emergency exit door so that it will not impede use of the exit;
(8 ) Assess the condition of an escape slide, activate the slide, and stabilize the slide after deployment to assist others in getting off the slide;
(9) Pass expeditiously through the emergency exit; and
(10) Assess, select, and follow a safe path away from the emergency exit.
(e) Each certificate holder shall include on passenger information cards, at each exit seat–
(1) In the primary language in which emergency commands are given by the crew, the selection criteria set forth in paragraph (b) of this section, and a request that a passenger identify himself or herself to allow reseating if he or she:
(i) Cannot meet the selection criteria set forth in paragraph (b) of this section;
(ii) Has a nondiscernible condition that will prevent him or her from performing the applicable functions listed in paragraph (d) of this section;
(iii) May suffer bodily harm as the result of performing one or more of those functions; or
(iv) Does not wish to perform those functions; and
(2) In each language used by the certificate holder for passenger information cards, a request that a passenger identify himself or herself to allow reseating if he or she lacks the ability to read, speak, or understand the language or the graphic form in which instructions required by this section and related to emergency evacuation are provided by the certificate holder, or the ability to understand the specified language in which crew commands will be given in an emergency.
(3) May suffer bodily harm as the result of performing one or more of those functions; or,
(4) Does not wish to perform those functions.
A certificate holder shall not require the passenger to disclose his or her reason for needing reseating.
(f) Each certificate holder shall make available for inspection by the public at all passenger loading gates and ticket counters at each airport where it conducts passenger operations, written procedures established for making determinations in regard to exit row seating.
(g) No certificate holder may allow taxi or pushback unless at least one required crewmember has verified that no exit seat is occupied by a person the crewmember determines is likely to be unable to perform the applicable functions listed in paragraph (d) of this section.
(h) Each certificate holder shall include in its passenger briefings a reference to the passenger information cards, required by paragraphs (d) and (e), the selection criteria set forth in paragraph (b), and the functions to be performed, set forth in paragraph (d) of this section.
(i) Each certificate holder shall include in its passenger briefings a request that a passenger identify himself or herself to allow reseating if he or she–
(1) Cannot meet the selection criteria set forth in paragraph (b) of this section;
(2) Has a nondiscernible condition that will prevent him or her from performing the applicable functions listed in paragraph (d) of this section;
(3) May suffer bodily harm as the result of performing one or more of those functions listed in paragraph (d) of this section; or,
(4) Does not wish to perform those functions listed in paragraph (d) of this section.
(j) [Removed and Reserved.]
(k) In the event a certificate holder determines in accordance with this section that it is likely that a passenger assigned to an exit seat would be unable to perform the functions listed in paragraph (d) of this section or a passenger requests a non-exit seat, the certificate holder shall expeditiously relocate the passenger to a non-exit seat.
(l) In the event of full booking in the non-exit seats and if necessary to accommodate a passenger being relocated from an exit seat, the certificate holder shall move a passenger who is willing and able to assume the evacuation functions that may be required, to an exit seat.
(m) A certificate holder may deny transportation to any passenger under this section only because–
(1) The passenger refuses to comply with instructions given by a crewmember or other authorized employee of the certificate holder implementing exit seating restrictions established in accordance with this section, or
(2) The only seat that will physically accommodate the person’s handicap is an exit seat.
(n) In order to comply with this section certificate holders shall–
(1) Establish procedures that address:
(i) The criteria listed in paragraph (b) of this section;
(ii) The functions listed in paragraph (d) of this section;
(iii) The requirements for airport information, passenger information cards, crewmember verification of appropriate seating in exit seats, passenger briefings, seat assignments, and denial of transportation as set forth in this section;
(iv) How to resolve disputes arising from implementation of this section, including identification of the certificate holder employee on the airport to whom complaints should be addressed for resolution; and,
(2) Submit their procedures for preliminary review and approval to the principal operations inspectors assigned to them at the certificate-holding district office.
(o) Certificate holders shall assign seats prior to boarding consistent with the criteria listed in paragraph (b) and the functions listed in paragraph (d) of this section, to the maximum extent feasible.
(p) The procedures required by paragraph (n) of this section will not become effective until final approval is granted by the Director, Flight Standards Service, Washington, DC. Approval will be based solely upon the safety aspects of the certificate holder’s procedures.
i know the exit row seating criteria and who may or may not sit there. I use to work for allegiant at the check in counter before becoming a flight attendant. but i have seen it happen. I was at the airport the other day talking to my friend who works for allegiant and she was telling me she checked in a pax who had prepurchased his seat and booked himself in exit row. when he showed up at the airport he had requested a wheelchair, my friend told him that since he was going to use a wheelchair he couldnt have the exit row. I dont agree with allegiant in being able to buy the exit row because of the situation that i just said, but you can with them
The truth of the matter is that TANSTAAFL was in use a couple of years before Heinlein’s novel.
The original usage was “There Ain’t No Such Thing as American Football League”. The TANSTAAFL cry was used by NY Giants fans to taunt NY Jets fans during their first game after the AFL merged with the NFL and became “the AFC of the NFL”.
It was a shameful day, but every Jets fan knows this fact to be true! Most want to forget it.
United to Charge $25 for Second Checked Bag
Starting next spring, United Airlines will begin charging certain domestic passengers for more than one piece of checked-in luggage to help offset the soaring cost of jet fuel, the No. 2 U.S. carrier said Monday.
Like I needed another reason to not fly United!!!
How much was that taxpayer bail out again?
Good job saving this topic Needle, it was almost a year since anyone had replied.
USAirways jumping on the bandwagon too. LINKIE.
Also mentioned in a seperate thread, but I figured I’d include it here as well as the list continues to grow.
I was on a flight last week and after we boarded the FA asked me if I would move to the exit row because it had been assigned to a woman and her three year old (CRJ200 2-2 configuration). How did check-in let that happen?
Offering conjecture only, it may be that the seat wasn’t actually assigned to the 3yo. Perhaps the mother bought only one ticket and the 3yo was supposed to be on the mother’s lap, but since there were extra seats on board they “asked” you to move.
But laps are restricted to children who have not yet attained the age of two (at least when I was an agent they were).
The key here is “exit row.” The baby is not allowed to sit in the emergency row.
Requirements for sitting in the emergency row are:
- be 15 years of age or older
- have the capacity to perform the applicable functions without the assistance of an adult companion, parent, or other relative
- have the ability to read and understand instructions related to emergency evacuation provided by Southwest in printed or graphic form
- have the ability to understand oral crew commands
- have sufficient visual capacity to perform applicable functions without the assistance of visual aids beyond contact lenses or eyeglasses
- have sufficient aural capacity to hear and understand instructions shouted by Flight Attendants without assistance beyond a hearing aid
- have the ability to adequately impart information orally to other passengers
The above is from the Southwest website. The requirements for other airlines are very similar, if not identical.
With Dami’s explanation, I now fully grasp the situation and utter the word “DUH”! (I feel stoopid and contagious)
In this “Information Age”, you can print your own boarding pass at home. If you’re not checking any baggage, then you just proceed from your car to your gate. Chances of gate agents catching a particular seat-assignment to a 3yo is pretty much nil. I guess it all rests on the flight attendants’ shoulders to ensure the people sitting in exit rows meet the proper qualifications.
On airlines with reserved seating, you think the reservations site would catch the fact that th person bought an adult ticket and a child’s ticket and not allow the person to reserve an emergency exit row seat. Same thing if the person made the reservations on the phone.
Of course, if the person bought a full fare for the baby then the site or the reservations agent wouldn’t be able to catch this.
Allegiant is pronounced Alle Giant… like alley Giant, like large person… just say Ben at hertz sed it!.. try it, pronounce it… allegiant alle giant
I don’t know if you caught it, but United and US Airways are adding the charge for the second bag (waived for elites and first class passengers).
Northwest jumping on the bandwagon too. LINKIE
