Hi all,
Each day there is an average of 30,000 flights within European airspace. I am interested in approximately 300 of those.
I realise Flightaware does not hold information on all carriers, however i can work with what you do have.
I need to search the API based on the ability to compare Schedule departure/arrival times with their Actual departure/arrival times
I would run this search on all european airports each 24 hour period unless ofcourse you have a search that will allow me to include my airports into the same query?
You will realise running this search a couple of times per day and being charged aprox 30,000 times per day vs only a few hundred times per day is the difference between affordable and unaffordable.
I am looking to do something similar to ‘Search’
:query => “-belowAltitude 100 -arrivalTime - -schedArrivalTime >= 45minutes” (obviously im trying to use math within the string query which i know is incorrect here. lso understand i would need to use epoch time to compare both sched and actual arrivals)
:howMany => ‘3,000’,
offset => 0,
return
Airline, flight number, origin, destination
THe above is a theory if requirement, i’ve tried to put this to your reports department and twice now they have referred me to your API so wanted to find a solution to my needs with your help?
Thank you in advance,
